Array
04-09-2015, 08:27 AM
Array
I have crate this simple array read program: EXPORT test() BEGIN Local T45BL = [5128122, 280602, 277693, 173237, 55413, 46271, 32573, 17198, 9266, 8822, 8216, 4324, 4200, -3359, 2463, 2211, 2065, -1870, 1828, -1794, -1749, -1565, -1491, -1475, -1410, -1344, -1335, 1107, 1021, 833, 777, 671, 607, 596, 491, -451, 439, 422, 421, -366, -351, 331, 315, 302, -283, -229, 223, 223, -220, -220, -185, 181, -177, 176, 166, -164, 132, -119, 115, 107]; for i from 0 to 59 do print(T45BL[i]); end; It it compiling well, but when executed I get the error message "Bad argument type" Can someone help me with this? Thanks for any help. Jan Kromhout Hellevoetsluis-NL |
04-09-2015, 10:45 AM
RE: Array
(04-09-2015 08:27 AM)Powersoft Wrote: Hello, Hello local T45BL:=[...] local i FOR i FROM 1 TO 60 DO |
04-09-2015, 10:59 AM
RE: Array
There were a few errors in the code you've shown but this should work:
04-09-2015, 11:06 AM
RE: Array
Would you be able to make use of the length() command in your loop?
04-09-2015, 02:27 PM
RE: Array
Thanks, this is great!
Would you be able to make use of the length() command in your loop? Code:
