commands to change settings modes for HOME and CAS but by software?
04-15-2015, 11:53 PM
(This post was last modified: 04-16-2015 05:32 PM by compsystems.)
Which are the commands to change modes?, for example exact mode to approximate mode and viceversa, and simplifications, none, maximun, and others of HOME-CAS settings etc
I found some to change angle and other settings? Code: export getMode_angle() I am creating a library for configuring modem by strings, which is much more intuitive than by numbers. if getMode_angle() == "RADIAN" then ... else ... end; setMode_angle( "RADIAN" ); setMode_angle( "DEG" ); Thanks for your reply |
04-06-2017, 11:38 AM
RE: commands to change settings modes for HOME and CAS but by software?
I would like to know this too, have you found anything out?
I want to save the calculators state, so I can change what I need for my program, and then restore it when it completes. Anyone know how to change calc settings through program? |
04-06-2017, 01:57 PM
You can save your settings by simply creating a list containing the various values of each setting. For example,
HVars("MySettings"):={ Language, HAngle, HFormat, HDigits }; will save the language, angle, number format, and digit settings. Then you can restore them with: LOCAL mysetttings:=HVars("MySettings"); Language:=mysettings(1); HAngle:=mysettings(2); HFormat:=mysettings(3); HDigits:=mysettings(4); As for programs that would allow users to use more descriptive names for settings, you can shorten your program considerably using a fixed list. For example, Code: AngleNames:={"Radians", "Degrees", "Gradians"}; You can also use just "RDG" along with instring() for something shorter: Code: export SetAngle(a) Graph 3D | QPI | SolveSys |
04-06-2017, 02:26 PM
(04-06-2017 11:38 AM)AngryNapkin Wrote: I would like to know this too, have you found anything out? You can modify the variables shown in the Help. These variables modify the general configuration (Home): These are used to manipulate Apps: Viga C | TD | FB |
04-07-2017, 03:11 AM
Thanks
04-09-2017, 01:34 PM
04-10-2017, 04:23 PM
(04-09-2017 01:34 PM)AngryNapkin Wrote: I would like to know this too, have you found anything out? Did you read the third and fourth post? Graph 3D | QPI | SolveSys |
04-15-2017, 03:09 PM
(This post was last modified: 04-15-2017 03:55 PM by AngryNapkin.)
That is strange, it posted my question twice here. I did read the posts, and I said thanks for the help. Why this is at the end is strange, and was not from me posting the same question.
I will ask further help with this though. I am able to change my angle "HAngle" from the home screen using HAngle:=0; But when I try this in a program, I get syntax error. Not sure what Is wrong. Never mind, found I was trying to change it outside the function. |
