operates the extraction of strings as []
04-20-2015, 03:34 PM
Phython operates the extraction of strings as subscripts [], This option PRIME facilitates the manipulation of string, that they are treated as arrays
HPPrime Syntax: MID(string, position, [n]) Extracts n characters from string starting at position. If n is not specified, then MID extracts the remainder of the string from position. Example: MID("MOMOGUMBO",3,5) returns "MOGUM" MID("PUDGE",4) returns "GE" Python ´abc´[1] retorna 'b', because Python strings are handled from position 0 ´abcdef´[0:2] retorna 'ab', the operator: inside the container [] is TO, as does also MATLAB |
