HP50g: Defining custom user keys that work also in the Equation Writer
04-21-2015, 05:16 AM (This post was last modified: 04-21-2015 05:17 AM by mirrro.)
Hey,
I try to implement this User Keyboard Assignment:
switching between:
INV() key:64.10
and
Y key:64.40
It works fine , but not in the Equation Writer and the Matrix Writer.
I tried also with KEYMAN , no luck there also,
Is that possible?
I use:
Hp50g
rom 2.15
Thanks for any help.
04-21-2015, 04:27 PM
RE: HP50g: Defining custom user keys that work also in the Equation Writer
(04-21-2015 05:16 AM)mirrro Wrote:  Hey,
switching between:
INV() key:64.10
and
Y key:64.40
Is that possible?
I use:
Hp50g
rom 2.15
I don't think this would work. Those applications have their own key definitions (assuming they were ported over from the HP48 series and not modified).
Graph 3D | QPI | SolveSys
04-23-2015, 10:02 PM
This old comp.sys.hp48 post from Joe Horn might help:
Quote:To force an HP49 key to "work" even when the command line exists, just
tack a "TakeOver" in front of it. To do that, put the desired key
definition on the stack, make sure library 256 is ATTACHed, and then do
this:
#275C6h A-> SWAP 2 ->PRG
The result will look the same as what you started with, but it will
have an invisible "TakeOver" in front of it. Now when you assign it to
a key, it'll work even in edit mode.
> The [HIST]-key is not usefull at all because [Arrow up] does the
> same.
One time that it's essential is when you're editing a program and need
to echo something from the stack into the program. Then pressing HIST
is the only way to start the interactive stack. (On the HP48 it was
done by a menu key, but The Powers That Be decided against that for the
HP49).
> But this is just an example there are several keys I'd like to change
You are NOT alone! ;-)
-Joe-
04-23-2015, 10:50 PM
(04-23-2015 10:02 PM)BruceH Wrote:  This old comp.sys.hp48 post [about TakeOver key assignments] from Joe Horn might help...
Unfortunately, neither the EquationWriter nor the MatrixWriter pay any attention to user key assignments, even if they have a TakeOver up front. Bottom line: No, you can't use your key assignments while running those applications.
<0|ΙΈ|0>
-Joe-
