HP 50g Format Sexagesimal Output
04-26-2015, 02:59 PM
This post is meant to correct my erroneous code posted on 06-29-2014, thread
HP 50g Surveyor's Stuff. The code does not cover all situations where there are
sixty seconds displayed, which is not allowed in sexagesimal measurement. I
would appreciate any help concerning my thought process and code.
// Format sexagesimal output
\<< 4 RND \->STR DUP
SIZE
\<< "59" SAME // check for 59 minutes
\<< STR\-> CEIL \->STR // add 1 degree
\<< STR\-> .01 + \->STR // add 1 minute
\>> IFTE
\>> \-> str size Degmin
CASE size 6 ==
THEN str 5 6
SUB "60" SAME // check for 60 seconds
\<< str 5 "00"
REPL DUP 3 4 SUB
Degmin EVAL
\<< str
\>> IFTE
END size 7 ==
THEN str 6 7
\<< str 6 "00"
REPL DUP 4 5 SUB
Degmin EVAL
\<< str
\>> IFTE
END size 8 ==
THEN str 7 8
\<< str 7 "00"
REPL DUP 5 6 SUB
Degmin EVAL
\<< str
\>> IFTE
END
END
checksum: # A374h
bytes: 508.5
Mark
04-26-2015, 03:42 PM
RE: HP 50g Format Sexagesimal Output
With [code ] tags around the listing, the text looks nicer.
(04-26-2015 02:59 PM)MNH Wrote:  Hello,
SIZE
      \>> IFTE
      CASE size 6 ==
        THEN str 5 6
        \<< str 5 "00"
REPL DUP 3 4 SUB
Degmin EVAL
        \<< str
        \>> IFTE
      END size 7 ==
      THEN str 6 7
        \<< str 6 "00"
REPL DUP 4 5 SUB
Degmin EVAL
        \<< str
        \>> IFTE
      END size 8 ==
      THEN str 7 8
        \<< str 7 "00"
REPL DUP 5 6 SUB
Degmin EVAL
        \<< str
        \>> IFTE
      END
    END
checksum: # A374h
bytes: 508.5
Mark
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
04-26-2015, 05:12 PM
Thanks for your reply! Is there an FAQ that describes the use of code tags?
04-26-2015, 07:00 PM
(04-26-2015 05:12 PM)MNH Wrote:  Is there an FAQ that describes the use of code tags?
The Help button (top right) should give you some clues.
Marcus von Cube
Wehrheim, Germany
http://wp34s.sf.net
