(33S) Pollard's Rho Factorisation
05-02-2015, 10:40 AM
(This post was last modified: 06-15-2017 01:25 PM by Gene.)
The main programme is SPLIT: given a positive composite integer input N, SPLIT returns a factor < N , possibly neither the smallest nor prime. Maximum value of N is 10^12-1.
LN= gives the size of the programme, CK= is the check sum - these two measures are depressingly meaningful in this calculator, if length or check sum is different on your machine, this has no transcendent meaning, you have simply mis-typed the programme. The sub programme F takes input integer & calculates the square modulo A, -A must be in B. F1 LBL F SQUARE MODULO F2 ENTER F3 ENTER F4 1000000 F5 RMDR F6 STO Z F7 - F8 ENTER F9 x2 F10 RCL B F11 RMDR F12 x<>y F13 RCL* Z F14 RCL A F15 RMDR F16 ENTER F17 RCL- A F18 + F19 RCL A F20 RMDR F21 + F22 RCL B F23 RMDR F24 RCL Z F25 x2 F26 + F27 RCL A LN=99 F28 RMDR CK=9D84 F29 RTN Given integers in stack levels X & Y programme X returns the greatest common divisor of the two integers. X1 LBL X GREATEST COMMON FACTOR X2 RMDR X3 LASTx X4 x<>y X5 x≠0? X6 GTO X X7 R↓ LN=27 X8 ABS CK=848A X9 RTN Programme L finds small factors of input N, the number to be factored. Line 21 suggests alternative upper limits for the search. L1 LBL L SMALL FACTORS L2 +/- L3 STO B L4 +/- L5 STO A L6 4 L7 x>y? L8 RTN L9 CLx L10 2 L11 RMDR L12 x=0? L13 RTN L14 RCL A L15 √x L16 FP L17 x=0? L18 RTN L19 LASTx L20 IP L21 113 Or 199 Or 283 L22 x>y? L23 x<>y L24 1000 L25 ÷ L26 300.002 LN=144 L27 + CK=BFDC L28 STO I A1 LBL A A2 RCL A A3 RCL I A4 IP A5 RMDR A6 x=0? A7 RTN A8 ISG I A9 GTO A A10 1 LN=48 A11 STO C CK=1B8C A12 RTN N1 LBL N N2 CLx N3 RCL A N4 x<>y N5 x≠y? LN=21 N6 RTN CK=33B3 N7 ISG C D1 LBL D POLLARD’S RHO D2 1 D3 STO V D4 STO U D5 RANDOM D6 RCL* A LN=36 D7 IP CK=9C81 D8 STO X J1 LBL J J2 XEQ F J3 RCL+ C J4 ENTER J5 RCL- X J6 RCL A J7 XEQ X J8 1 J9 x≠y? J10 GTO N J11 R↓ J12 R↓ J13 DSE U J14 GTO J J15 RCL V J16 RCL+ V J17 STO V LN=69 J18 STO U CK=3D16 J19 R↓ V1 LBL V V2 XEQ F V3 RCL+ C V4 DSE U V5 GTO V V6 STO X V7 RCL V LN=30 V8 STO U V9 R↓ CK=098A V10 GTO J S1 LBL S SPLIT S2 XEQ L S3 x≠0? S4 GTO D S5 RCL A LN=21 S6 LASTx CK=90F8 S7 RTN |
