Arduino Bluetooth + HP41c
05-02-2015, 02:23 PM
I'm readying for IoT word in SFO this month and I started to explore a number of bluetooth options - as small as possible. I came across something called RFDuino, which looked like it could be the answer to the connection dreams for the HP41c. It fits in a pac module and has enough IO, as well as low power BTLE and a simpler programming support. If this had the ability to emulate a ROM Pac and connect via Bluetooth, then then the opportunities are endless?
The best thing is that the device is only around $15 per unit.
05-04-2015, 01:50 AM
RE: Arduino Bluetooth + HP41c
The space inside a module housing is only about 13mm x 23mm, so the 15mm^2 RFDuino probably wouldn't fit. Especially considering that you would also need a voltage regulator and at least a couple of level shifters. Close, though.
