(50G) PDQ Algorithm in SRPL and URPL
05-04-2015, 04:48 PM
(This post was last modified: 06-15-2017 01:40 PM by Gene.)
PDQ Algorithm in HP 50g System RPL and User RPL, by Joe Horn
Here are two HP 50g versions of the "PDQ Algorithm", fully described HERE. The first version is in System RPL (more or less), and the second is 100% User RPL. They are identical in operation except for speed: the System RPL version is roughly twice as fast as the User RPL version. Example: 5. √ 2 PDQ --> 29/13 SRPL version: 0.37 seconds URPL version: 0.78 seconds Differences from the Prime version linked above: (1) Inputs: Stack level 2: Number to be approximated (as a real decimal, integer ratio, or string). Stack level 1: Tolerance (as a real decimal, or integer ratio). Allowing the inputs to be in the form of integer ratios or strings is what lets the user tap the "infinite precision" of the algorithm (see examples below). (2) Outputs: Stack level 2: Exact best fraction Stack level 1: Exact error (tagged "N" or "X") "N" means "Normal" (principal) convergent "X" means "eXtra" (intermediate) convergent Examples: 3.14159265359 7 PDQ --> 75948/24175, X:-9602153/96700000000000 What this means: The input means, "What is the simplest fraction within ±1/10^7 of 3.14159265359?" The answer is 75948/24175, which is an intermediate convergent of the input (that's what the "X" indicates). The answer differs from the input by exactly -9602153/96700000000000. '31415926535897932384626/10000000000000000000000' '1/800' PDQ --> 179/57, X:exact error (ratio of two large integers) "3.1415926535897932384626" .00125 PDQ --> same as previous example (3) 'ic' and 'err' global variables are not created. (4) Since the 50g uses 12-digit BCD, and Prime's CAS uses 48-bit binary floating point, real inputs on both machines will usually be slightly different, which can cause PDQ's results to differ on both machines. When their inputs are actually identical (e.g. when they are exact ratios of integers), PDQ's results will also be identical on both machines. PDQ in System RPL BYTES (when assembled): 852. #A4ABh Code: %%HP: T(3)A(R)F(.); PDQ in User RPL BYTES: 818.5 #7596h Code: %%HP: T(3)A(R)F(.); <0|ɸ|0> -Joe- |
08-26-2015, 09:19 PM
RE: (50g) PDQ Algorithm in SRPL and URPL
(05-04-2015 04:48 PM)Joe Horn Wrote: PDQ Algorithm in HP 50g System RPL and User RPL, by Joe Horn I'm completely new, and I've been trying to get this to work, so far I'm not having any luck. First, I tried cut-and-pasting this into an editor (vim), set the line-endings to unix, then saved that as a file on a SD card. I stuck the card back into the HP, in the filer, I navigated to the right place, put my cursor on Code: "..." PDQ STRNG 2414 I then typed out ASM, and got back the message asm Error: Invalid File. So, what did I actually need to do instead? (Post 4) Regards, BrickViking |
08-27-2015, 12:13 AM
(08-26-2015 09:19 PM)brickviking Wrote: So, what did I actually need to do instead? The way the listings are posted, with the "%%HP: T(3)A(R)F(.);" at the top, they are intended to be transferred to the 50g using the HP ConnKit. The %%HP.... directives are instructions to tell the ConnKit how to translate the file when downloading. If you copy as a string via the SD card, remove this top line as it has no meaning to the SysRPL compiler. --Bob Prosperi |
08-27-2015, 05:14 AM
(This post was last modified: 08-27-2015 05:45 AM by brickviking.)
Okay. What step do I do after I've transferred it to the calculator? It's in my Home directory at the moment, as a STRNG object, 2382 bytes long. Do I put the cursor on it in the Filer, and hit Eval?
This would put the object into my stack, after which, I hit ON and then I should type ASM ? Doing this shows me (after MASD finishes) with the following: Code:
Now, do I store that into a varname, like .. ooo, I dunno. ->PDQ ? Ah, found it in UsrRPLTut. PDQ Enter, STO> Cheers for your patience. (Post 6) Regards, BrickViking |
08-27-2015, 05:19 AM
What is the command "x\->LST"?
08-27-2015, 01:57 PM
(08-27-2015 05:19 AM)Gerald H Wrote: What is the command "x\->LST"? Also known as "ROMPTR 100 A", it's one of the built-in Development Library commands. It's similar to →LIST, but it also converts programs and algebraic objects to lists. If you type 256.02 MENU, you'll see it on the F5 key. If you keep library 256 attached (a good idea), you'll also be able to see it by pressing [APPS] [up-arrow] [ENTER] [NXT]. If you set flag -86, your 50g will automatically attach library 256 at every warmstart. In the AUR, →LST is described on page 6-6 (which is page 504 in the PDF version). <0|ɸ|0> -Joe- |
08-27-2015, 04:24 PM
Thanks, Joe, don't know how I could have missed the command previously, seems extremely useful.
pdq programme works nicely on 50G, nicely optimised for User RPL. |
09-11-2015, 06:08 PM
Hi Joe,
Thank you for contributing your PDQ code for both the HP Prime and 50G. Just as a matter of curiosity, though, I was wondering why your SysRPL code was not "purge" SysRPL and instead is a combination of of SysRPL and regular UserRPL. Han Graph 3D | QPI | SolveSys |
09-12-2015, 03:58 AM
(09-11-2015 06:08 PM)Han Wrote: Thank you for contributing your PDQ code for both the HP Prime and 50G. Just as a matter of curiosity, though, I was wondering why your SysRPL code was not "purge" SysRPL and instead is a combination of of SysRPL and regular UserRPL. Assuming that you meant "pure" SysRPL, the answer is that my only goal was to improve the speed. The inner loop, where most execution time is spent, is pure SysRPL, so my goal was achieved. Converting the rest of the program into pure SysRPL is left as an exercise for people with more free time and patience than I have. <0|ɸ|0> -Joe- |
09-12-2015, 04:59 AM
(09-12-2015 03:58 AM)Joe Horn Wrote:(09-11-2015 06:08 PM)Han Wrote: Thank you for contributing your PDQ code for both the HP Prime and 50G. Just as a matter of curiosity, though, I was wondering why your SysRPL code was not "purge" SysRPL and instead is a combination of of SysRPL and regular UserRPL. While I doubt that I have more patience than Joe I have increased the extent of sys commands in the programme, however some of the user commands are flexible in just the way needed in the programme & concise. I will publish in due course & hope someone else beats me to it. |
02-23-2019, 09:09 PM
RE: (50G) PDQ Algorithm in SRPL and URPL
(05-04-2015 04:48 PM)Joe Horn Wrote: PDQ Algorithm in HP 50g System RPL and User RPL, by Joe Horn belated thank you Joe. Is there a SysRPL version for HP48 anywhere? I can't seem to find one… or should I just use the UserRPL version above? thanks very much. Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
02-24-2019, 07:54 AM
(02-23-2019 09:09 PM)cdmackay Wrote: Is there a SysRPL version for HP48 anywhere? I can't seem to find one… Unfortunately, the User RPL program above cannot be used on the HP 48, because it uses long integers, which is an object type which was introduced into RPL with the HP 49G (after the HP 48). However, you might enjoy a less powerful version (limited to the HP 48's range of 12-digit mantissas) which was posted by Bill Wickes to the comp.sys.handhelds newsgroup on 2 April 1991, and included on Goodies Disk #3. Its commented source code follows. Don't worry about the SYSEVAL; it should work in any HP 48. Code: %%HP:T(3)F(.); <0|ɸ|0> -Joe- |
02-24-2019, 05:19 PM
(02-24-2019 07:54 AM)Joe Horn Wrote: Unfortunately, the User RPL program above cannot be used on the HP 48, because it uses long integers, thanks very much indeed, Joe. Indeed, I'd read about the long integer issue, and then forgotten, sorry. I didn't find those posts, I think because I was searching for "PDQ". I'll add both HP's NEW2Q and your SysRPL D2F to my 48GX, thanks! Cambridge, UK 41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47 Casio, Rockwell 18R |
