(49G) FPTR2^ZSQRT Replacement
05-14-2015, 02:50 PM
(This post was last modified: 09-08-2017 04:40 PM by Gerald H.)
Edit: Programme changed to remove uncommon names for pointers etc.
The built in integer square root-finder function returns the integer square root of N a positive integer & TRUE/FALSE if the square of the answer is exactly N or not. Sadly the square root of larger integers is not calculated correctly. eg For entry 8057607683965968206853219945486680251051474004852138 FPTR2^ZSQRT returns 89764178177967899999999999 (incorrect value) & FALSE. The programme below returns 89764178177967898147413811 (correct value) & FALSE. Programme name: ISQRT Size: 125. CkSum: # 6291d Code: :: |
09-08-2017, 04:43 PM
RE: (49G) FPTR2^ZSQRT Replacement
Please note progamme has been edited to remove ?_
