Orbital Elements
05-17-2015, 06:20 PM
(This post was last modified: 05-17-2015 06:21 PM by Eddie W. Shore.)
Orbital Elements
Link: http://edspi31415.blogspot.com/2015/05/h...bital.html
Input: Three types of unit systems that can be used: MI-LB-S: Miles-Pounds-Seconds KM-KG-S: Kilograms-Kilometers-Seconds MU=1: Sets the gravitational parameter (μ) to 1. Used for problems involving canonical units. Radius vector: position where the satellite is located relative to the celestial object the satellite is orbiting around. Celestial objects include planets and stars. Velocity vector: velocity of the satellite. Canonical Units: The distance unit is set between the average distance between the satellite and its reference celestial object. The time unit is selected such that the velocity of the satellite is 1 distance unit per time unit. This ensures that μ = 1. Output: Angular Momentum Vector Node Vector Inclination Angle of the satellite: angle between the z-axis (J vector [0,0,1]) and the angular momentum vector. Longitude Angle: the angle between the I vector ([1,0,0]) and when the satellite crosses the fundamental plane. For orbits around Earth, the measure statements from the vector pointing towards the Vernal Equinox (known as the First Point of Aries*) and going eastward. (Even though today, in 2015, the Vernal Equinox is in the constellation Pisces, slowly moving towards Aquarius.) Eccentricity: The eccentricity of the orbit. The vector and the norm is given. The eccentricity determines the path of the orbit: If e = 0, the orbit is a circle. If e < 1, the orbit is an ellipse. If e = 1, the orbit is a parabola. If e > 1, the orbit is a hyperbola. ** The HP Prime version sets the calculator to Fixed 5 decimal mode. All results shown are rounded to five digits. Code: EXPORT ORBELEM(M,vr,vv) Example: A satellite orbiting Earth (mass of 1.3170 * 10^25 pounds) has a radius vector of [[ 14700, 18268, 11500 ]] (miles) with the velocity of [[ 3.5, 4.5, 3.2 ]] (miles/sec). Recall that an hour is 3600 seconds. Then: Angular Momentum Vector: [[ 6707.6, -6790, 2212]] Node Vector: [[6790, 6707.6, 0]] Incidence Angle: 76.95158555° Longitude Angle: 44.6502257° Eccentricity: 1, Parabola Source: Roger R. Bate, Donald D. Mueller, Jerry E. White. “Fundamental of Astrodynamics” Dover Publications, Inc. New York: 1971 |
