41CV new owner questions
05-26-2015, 12:51 PM
Post: #21
RE: 41CV new owner questions
(05-26-2015 11:26 AM)Dieter Wrote:(05-22-2015 03:59 AM)TASP Wrote: An XMEM or 2 will need an XFUN also. Just on principle I'd suggest a Rev. C, but a deal on a B or an unknown would be worth watching for. Also, a Rev. G card reader is suggested if you're serious about the XMEM, the VER bug is annoying, but not everyone VERs cards as much as I do. Hi Dieter! Here's an hint from an old thread. Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
05-26-2015, 12:58 PM
Post: #22
The VER function will corrupt one data register in the XM. Can't recall offhand if it is the 'second' or 'third' block of XM. Rev. G (and higher if they made them) card readers have had the VER function modified to not bother the XM.
PPCJournal had a routine for allowing use of the VER function in rev. F and earlier card readers, but I'm not recalling what issue it was in. 2speed HP41CX,int2XMEM+ZEN, HPIL+DEVEL, HPIL+X/IO, I/R, 82143, 82163, 82162 -25,35,45,55,65,67,70,80 |
05-26-2015, 01:52 PM
Post: #23
Keith Jarret's book, HP-41 Extended Functions Made Easy, in the "Bugs" chapter (pages 3-5) notes the Rev. B XFun has a problem with SAVEP, PCLPS, and PURFL and gives a longer discussion of the problems on pages 12 and 13, and pages 19 thru 21.
Revision C fixes those bugs, or if you have a Rev B, Keith's book has solutions for that module. The CX has a built in XFun with more features, and does not have the above bugs. A CX will experience the VER bug if it has additional XM and is used with a Rev F or earlier card reader. THANX Keith !! 2speed HP41CX,int2XMEM+ZEN, HPIL+DEVEL, HPIL+X/IO, I/R, 82143, 82163, 82162 -25,35,45,55,65,67,70,80 |
