Programming Question for Stats
05-19-2015, 02:38 AM
Goal: Develop a program that determines the best fit between various regression types (the first six: Linear, Logarithmic, Exponential, Power, Exponent, Inverse).
However, I am getting the same correlation for each of the types. Here is the code (FW 7820):
EXPORT BESTFIT(xlist,ylist)
// 2015-05-15 EWS
// 2015-05-18
LOCAL clist,k,m,p,c;
STARTAPP("Statistcs2Var");
C1:=xlist;
C2:=ylist;
S1(1):='C1';
S1(2):='C2';
CHECK(1);
clist:={};
// testing
FOR k FROM 1 TO 6 DO
S1(4):=k;
Do2VStats(S1);
c:=CoefDet;
// during execution c
// is the same despite
// type being changed
clist:=CONCAT(clist,{c});
//find and display results
m:=MAX(clist);
p:=POS(clist,m);
S1(4):=p;
Do2VStats(S1);
// My intended results
//RETURN "Type: "+STRING(p)
//+", Coef: "+STRING(Corr,2,4);
RETURN clist;
Advice?
