LINE, LINE_P ?
05-19-2015, 08:34 AM
LINE, LINE_P ?
I've noticed many commands that output to the screen have two variants, either with or without '_P'. What is the difference ?, the manual shows both but tends to use the _P variant as an example.
Sorry for such simple questions Smile
05-19-2015, 08:54 AM
RE: LINE, LINE_P ?
See the details under "Drawing" on page 531. In summary "_P" commands use pixel coordinates to address the screen, while non "_P" commands use Cartesian coordinates where the screen is mapped to a plane defined by Xmin, Xmax, Ymin, and Ymax.
05-19-2015, 09:44 AM (This post was last modified: 05-19-2015 09:54 AM by Digitaldreams.)
RE: LINE, LINE_P ?
Thanks Didier...not got much time to read through the manual...
05-19-2015, 10:10 AM
RE: LINE, LINE_P ?
Here's a little skeleton program that shows a way to use colors by name:
EXPORT test()
  local red:=rgb(255,0,0),
         green:=rgb(0,255,0),
         blue:=rgb(0,0,255),
         yellow:=rgb(255,255,0);
  rect();                                        // clear graphic screen
  rect_p(75,1,265,16,blue);                      // present blue rectangle
  textout_p("Digitaldreams",G0,130,4,2,yellow);  // put your name in the marquee
  wait (-1);  // admire your name for awhile
-Dale-
05-19-2015, 11:38 AM
RE: LINE, LINE_P ?
Thanks Dale, noticed the RGB command.....Gee the Prime draws circles fast !
