(49G) Extended Real Integer Partitions Programme
05-23-2015, 04:38 PM (This post was last modified: 10-21-2017 04:42 PM by Gerald H.)
For positive integer extended real input the programme returns the number of integer partitions as an extended real.
eg For entry %% 300 the programme returns %% 9.25308293663826E+00015, the correct value being 9253082936723602.
For entry %% 3.45678E+00005 the result is %% 3.93486234859078E+00648.
Wolfram Alpha returns see below.
  CK1&Dispatch
  # 3F
    DUP
    %%0<
    caseSIZEERR
    %%INT
    DUP
    %%0=
    casedrop
    %%1
    DUPDUP
    SWAP
    %% 4.16666666666667E-2
    DUP
    %%SQRT
    DUPUNROT
    SWAP
    %% 8.16496580927726E-1
    %%PI
    2DUPSWAP
    %%4
    %%1/
    %%2PI
    DUP
    BINT0
    %%0
    DUPDUP
    NULLLAM
    BINT10
    NDUPN
    DOBIND
    BINT0
    DROP
    %%0
    4GETLAM
    #1+DUP
    4PUTLAM
    DUP
    UNCOERCE%%
    2PUTLAM
    #1+_ONE_DO
    4GETLAM
    INDEX@
    DUP
    UNCOERCE%%
    3PUTLAM
    DUPUNROT
    DROP
    #0=UNTIL
    DROP
    #1=
    IT
      6GETLAM
      4GETLAM
      #1-
        DUP#0=csDROP
        #1+_ONE_DO
        INDEX@
        UNCOERCE%%
        2GETLAM
        DUP
        3GETLAM
        DUP
        %%INT
        %%.5
        SWAP
        %%.5
        LOOP
      10GETLAM
      3GETLAM
      2GETLAM
      %%PI
      %%COSRAD
    LOOP
    8GETLAM
    2GETLAM
    %%EXP
    DUP
    %%1/
    2DUP
    7GETLAM
    2GETLAM
    3UNROLL
    9GETLAM
    2GETLAM
    %%SQRT
    5GETLAM
    DUPROT
    1GETLAM
    DUP1PUTLAM_
    DUPUNROT
    %%.5
    %%INT
    SWAP
    %%.5
    %%INT
    OVER
    EQUAL
    UNTIL
    ABND
Attached File(s) Thumbnail(s)
