(49G+) IBM Check Digit Programme
05-27-2015, 07:00 AM (This post was last modified: 06-15-2017 01:47 PM by Gene.)
For positive integer input the programme returns the original input and the check digit.
eg For input
18081953
18081953
4
For more info on IBM check digit see
http://en.wikipedia.org/wiki/Luhn_algorithm
Edit: Programme faulty, see next posting.
  CK1&Dispatch
  # FF
    DUP
      BINT0
      BINT2
      BINT4
      BINT6
      BINT8
      BINT1
      BINT3
      BINT5
      BINT7
      BINT9
    SWAPDUP
    PTR 2F3A3
    COERCEDUP
    BINT2
    #<case
    DROPSWAPDROP
    BINT0
    3UNROLL
    ZERO_DO
    Z10_
    FPTR2 ^ZDIVext
    FPTR2 ^Z2BIN
    INDEX@
    BINT2
    DROP
    #0=
    IT
      #1+
      4PICKSWAP
      NTHCOMPDROP
    ROT#+
    BINT10
    DROP
    SWAPLOOP
    DROPSWAPDROP
    BINT10
    SWAP#-
    FPTR2 ^#>Z
05-29-2015, 10:46 AM
RE: HP 49G+: IBM Check Digit Programme
Sorry, error in above programme, corrected here:
  CK1&Dispatch
  # FF
    DUP
      BINT0
      BINT2
      BINT4
      BINT6
      BINT8
      BINT1
      BINT3
      BINT5
      BINT7
      BINT9
    SWAPDUP
    ID x010
    DUP
    BINT2
    #<case
    DROPSWAPDROP
    BINT0
    3UNROLL
    ZERO_DO
    Z10_
    FPTR2 ^ZDIVext
    FPTR2 ^Z2BIN
    INDEX@
    BINT2
    DROP
    #0=
    IT
      #1+
      4PICKSWAP
      NTHCOMPDROP
    ROT#+
    BINT10
    DROP
    SWAPLOOP
    DROPSWAPDROP
    DUP#0=csedrp
    Z0_
    BINT10
    SWAP#-
    FPTR2 ^#>Z
