Prime: Key Assignment
01-11-2014, 05:22 PM
Having read the manual (p 516/517) I was under the impression that all key assignments would do was to return a function or other text using the RETURN command. I played around using this command, but found it very difficult to make any key assignments of much use. Then when reading another message on the forum I was directed to an article on the comp.sys.hp48 where a person called Toby had made a short key assignment to scroll through Textbook, Algebra and RPN input settings.
To my surprise his method did not rely on the RETURN command at all, and still worked fine. As I have not found this being discussed elsewhere on the forum, I thought it worthwhile to mention, also that you can have several key assignments in one program file.
Below is an example key assignment file, that allows toggling between RPN and Textbook (I have not had occasion to use the Algebra setting at all so far) and also between Radians and Degrees, both in Home view.
I have kept the code in a file called User Keys
// Toggle switch RPN/Textbook
KEY K_On()
 IF Entry == 0
  THEN Entry:=2
  ELSE Entry:=0;
//Trick to refresh screen
STARTVIEW(−8,1);
STARTVIEW(−1,1);
// Toggle switch Deg/Radians in Home view
KEY K_Eex()
 IF HAngle == 0
  THEN HAngle:=1
  ELSE HAngle:=0;
STARTVIEW(−8,1);
STARTVIEW(−1,1);
Cheers, Terje
01-11-2014, 09:02 PM
RE: Prime: Key Assignment
Yep, I've managed to make keys to change the angle mode, for example.
What we really need is the old KEYEVAL command, though. Outputting "+" is not the same as pressing the + button!
That said, one thing I do rather like about PPL KEY assignment is that it's pleasantly easy and transparent to do some things with keys that were a pain to do with UserRPL.
01-11-2014, 10:38 PM
(01-11-2014 09:02 PM)The Shadow Wrote:  Yep, I've managed to make keys to change the angle mode, for example.
You can get the equivalent of keyeval by simply returning the key number.
Graph 3D | QPI | SolveSys
01-13-2014, 05:19 PM
Hi Han,
How do you do that? Is it using the RETURN command? I cannot find any reference of that on the manual. I would like, for example, to send a ESC command at the end of a program.
Thanks and regards,
Miguel
01-13-2014, 07:03 PM
(01-13-2014 05:19 PM)Miguel Toro Wrote:  Hi Han,
Thanks and regards,
Miguel
My post should probably have clarified that the keyeval effect was limited to the user keys. That is, one may redefine a user key by returning the keynumber. For example,
KEY K_7()
  RETURN(39);
This turns the 7 key into the 6 key on the Home screen. You can put additional commands above the return(39) statement if you want to do some pre-processing before sending it over to the system keyhandler.
01-13-2014, 10:19 PM
(01-13-2014 05:19 PM)Miguel Toro Wrote:  I would like, for example, to send a ESC command at the end of a program.
Thanks and regards,
Miguel
If by ESC you mean to clear the screen and return to Home after a User key has been used you can add the following two lines to the end of the Key definition:
STARTVIEW(−8,1);
STARTVIEW(−1,1);
Maybe you were thinking of something different?
Cheers, Terje
01-13-2014, 10:47 PM
Thank Han and Terje for your answers.
Miguel
User(s) browsing this thread:
