Bug in (7820) - REDIM
06-04-2015, 04:51 PM
REDIM does not work in Home, but works in CAS. In the program can be used CAS.REDIM but it's slower than it should.
06-04-2015, 04:57 PM
RE: Bug in (7820) - REDIM
(06-04-2015 04:51 PM)slawek39 Wrote: REDIM does not work in Home Works fine here... REDIM(M1,{2,3}), REDIM(u1,5) etc ??? TW Although I work for HP, the views and opinions I post here are my own. |
06-04-2015, 05:04 PM
(This post was last modified: 06-04-2015 05:08 PM by slawek39.)
RE: Bug in (7820) - REDIM | |||
06-04-2015, 05:28 PM
06-04-2015, 06:37 PM
To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode.
06-06-2015, 05:56 AM
(06-04-2015 06:37 PM)John Colvin Wrote: To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode. Correction: REDIM does work in RPN mode, but you gotta use it with RPN syntax (because you're in RPN mode!). Example: 'M1' [Enter] {3,4} [Enter] REDIM [Enter] <0|ΙΈ|0> -Joe- |
06-06-2015, 06:07 AM
06-06-2015, 06:33 PM
(06-06-2015 05:56 AM)Joe Horn Wrote:I used the matrix template to create the matrix and then stored it in M1. Then I entered(06-04-2015 06:37 PM)John Colvin Wrote: To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode. 'M1' and { 3, 4} and REDIM()--no change. Maybe something in the settings. |
06-07-2015, 02:33 AM
Anyway, does appear to be an issue here. Its on the list to resolve. Thanks.
