Matrix range
06-06-2015, 06:14 PM
(This post was last modified: 06-07-2015 07:22 AM by salvomic.)
Matrix range
I didn't know, but inputting M1(1..2) Prime return matrix M1 with the first 2 rows...
There is a trick to get also the first two columns like that? Another thing: mat:= delcols(m, (r+1) .. c); doesn't run in a program (in Home it complains that there are two decimal dots...; in CAS gives error also): any other simple command to extract a range from a matrix? EDIT: found this other thing: SUB(m, {1,1}, {r,r}); Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
06-07-2015, 03:29 AM
RE: Matrix range
(06-06-2015 06:14 PM)salvomic Wrote: I didn't know, but inputting M1(1..2) Prime return matrix M1 with the first 2 rows... Not a "trick", but col(M1,1..2) in CAS returns the first two columns of M1. <0|ɸ|0> -Joe- |
06-07-2015, 07:21 AM
RE: Matrix range
(06-07-2015 03:29 AM)Joe Horn Wrote: Not a "trick", but col(M1,1..2) in CAS returns the first two columns of M1. oh, thanks! it works ![]() Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
