Truncate decimal part of angle (DEG)
06-18-2015, 10:28 AM
hi,
what's the command to truncate the decimal part of an angle (DEG format). I mean: I've 3°12'22".12345 and I want 3°12'22" without the .12345 Using IP() I get 3°00'00", with truncate() I get 3°12'22.12345" ... thank you, Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
06-18-2015, 11:47 AM
(This post was last modified: 06-18-2015 11:49 AM by DrD.)
RE: Truncate decimal part of angle (DEG)
For that specific example, 3°12′22.12345″, this works:
LEFT(STRING(3°12′22.12345″),7) --> "3°12′22" You can probably figure out a more general approach. |
06-18-2015, 11:59 AM
(06-18-2015 11:47 AM)DrD Wrote: For that specific example, 3°12′22.12345″, this works: good idea, Dale, thank you. I'm thinking about it... ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
06-18-2015, 12:11 PM
This should work with any angle:
→HMS((IP(HMS→(3°12′22.12345″)*3600)/3600)) |
06-18-2015, 12:14 PM
(06-18-2015 12:11 PM)Didier Lachieze Wrote: This should work with any angle: simple, but great! it works, thank you. Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
