[WP 34S] I/O Error
06-19-2015, 03:09 AM
[WP 34S] I/O Error
I upgraded my 34S with Harald's USB board. After troubleshooting some bad soldering (I'm an amateur!), I have a working USB board. One issue I have noticed is that I get an I/O Error when transferring, for example, the stats registers to the Windows Emulator. Transferring from the Windows Emulator to the 34S seems to work fine.
Could I get some pointers on what to look for? Tips, suggestions welcome. Thanks in advance!
-- Sanjeev Visvanatha
06-19-2015, 10:52 AM (This post was last modified: 06-19-2015 11:02 AM by Marcus von Cube.)
RE: [WP 34S] I/O Error
(06-19-2015 03:09 AM)Sanjeev Visvanatha Wrote:  I upgraded my 34S with Harald's USB board. After troubleshooting some bad soldering (I'm an amateur!), I have a working USB board. One issue I have noticed is that I get an I/O Error when transferring, for example, the stats registers to the Windows Emulator. Transferring from the Windows Emulator to the 34S seems to work fine.
I fear this is a bug in the Windows emulator. It looks like a race condition. Have you tried Pascal's Qt implementation? This might work better then mine.
Edit: I assume that you have the crystal installed on your device. Otherwise it might help to enter a speed factor in X (between 80 and 120, value in %) on the calculator before starting the transfer.
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
06-19-2015, 07:55 PM
(06-19-2015 10:52 AM)Marcus von Cube Wrote:  I fear this is a bug in the Windows emulator. It looks like a race condition. Have you tried Pascal's Qt implementation? This might work better then mine.
Yes, I have the capacitors and crystal installed, and they seem to work.
I have not tried Pascal's QT emulator, but it appears from the SourceForge code tree that I have to compile it myself. Are there any executables available for Windows (XP) that are available somewhere to test?
06-19-2015, 08:10 PM
(06-19-2015 07:55 PM)Sanjeev Visvanatha Wrote:  I have not tried Pascal's QT emulator, but it appears from the SourceForge code tree that I have to compile it myself. Are there any executables available for Windows (XP) that are available somewhere to test?
See here: http://sourceforge.net/projects/wp34s/files/emulator/
Marcus von Cube
Wehrheim, Germany
http://wp34s.sf.net
06-19-2015, 08:16 PM
In http://sourceforge.net/projects/wp34s/files/emulator/
06-20-2015, 12:43 AM
Marcus, Pascal: Thank you for the links! From some testing performed between the two emulators, it does indeed seem to appear that the Windows Emulator doesn't receive, while the Qt Emulator does.
