Recursive sequences in CAS on prime.
06-19-2015, 07:22 AM
Hello
I can't figure out how to define a recursive sequence in CAS on the HP prime.
I want to define:
u(1)=3/2
u(2)=5/3
u(n)=2003-6002/u(n-1)+4000/(u(n-1)u(n-2))
Of course, I can define this sequence in the sequence app in HOME mode but it gives wrong answers (the sequence is made for that purpose Smile ) so I want to have exact values in CAS.
I made a CAS program with a FOR loop and it works fine but I'm looking for a more straightforward way to do this.
In XCAS, I can type in
u(n):={si n==1 alors 3/2; sinon si n==2 alors 5/3; sinon 2003-6002/u(n-1)+4000/(u(n-1)*u(n-2)); fsi; fsi;}
and it works.
I am looking for a similar syntax working on the prime too.
thank you for your help.
06-19-2015, 09:01 AM
RE: Recursive sequences in CAS on prime.
Here is a solution:
#cas
mf(n):=
IF n==1 THEN
RETURN(3/2);
ELSE
IF n==2 THEN
RETURN(5/3);
RETURN(2003-6002/mf(n-1)+4000/(mf(n-1)*mf(n-2)));
#end
which seems to work in your desired way. It provides exact values at least until n=10, now I am trying 25 and this runs now the fifth minute on the emulator which is due to the 3 recursive calls in the code, so I cancelled it.
Arno
06-19-2015, 09:20 AM
Thank you. This is a way to do this. But is there another way, without making a CAS program ? with a declaration like u(n):= ... ?
06-19-2015, 10:33 AM
Hello Arne,
maybe your program runs faster, if you create two local variables, wich get the values of mf(n-1) and mf(n-2), so you have to do the recursive call only twice ind not three times.
regards
Wolfgang
06-19-2015, 02:12 PM
(06-19-2015 10:33 AM)ww63 Wrote:  Hello Arne,
regards
Wolfgang
Yes, you are right, a reduction of recursive calls is necessary. But your solution, I think, will not work with local variables as they are created each time when the function is called. Here additional Parameters are necessary to pass the last two values and then the solution with a for-loop seems better.
Arno
06-19-2015, 04:37 PM
I managed to declare the sequence directly in CAS:
u:=(n)->CASE IF (n==1) THEN 3/2 END IF (n==2) THEN 5/3 END IF n>2 THEN 2003-6002/u(n-1)+4000/(u(n-1)*u(n-2)) END END
It works fine until n>10. After this, the recursion is too deep.
I made a CAS program too with a FOR loop :
#cas
u(n):=
LOCAL r,r1,r2
CASE
IF n==1 THEN RETURN 3/2; END;
IF n==2 THEN RETURN 5/3; END;
DEFAULT
r1=3/2
r2=5/3
FOR I FROM 3 TO n DO
r := 2003-6002/r2+4000/(r1*r2);
r1:=r2;
r2:=r;
RETURN r;
#end
But after all this, I think my favorite method is to use the spreadsheet with cells in CAS mode. It is fast and quite easy.
