[WP 34s] Matrix multiplication procedure
06-22-2015, 10:32 PM
(This post was last modified: 06-22-2015 10:36 PM by Marcio.)
Hello all,
Would you be kind enough as to explain with an example how to do matrix multiplication in the 34s? So far I have only been able to invert them, mostly because all it takes is store the data in \(R_n\) and then call \(M^{-1}\) with the descriptor in \(x\). Quite easy. As to multiply matrices, the manual says the descriptors should be in \(z\) and \(y\), the problem however is that I don't quite understand what should be in \(x\). Very much appreciated. Marcio |
06-22-2015, 11:30 PM
(This post was last modified: 06-22-2015 11:38 PM by Thomas Klemm.)
RE: [WP 34s] Matrix multiplication procedure
WP 34S pocket reference
M× z y x → r Take two matrix descriptors y and z, and the integer part of x as the base address of the re- sult. Returns (Z)·(Y)=(X). All calculations are done in internal high precision (39 digits). The fractional part of x is updated to match the resulting matrix - no overlap checking is performed. (06-22-2015 10:32 PM)Marcio Wrote: the problem however is that I don't quite understand what should be in \(x\). That is the matrix-descriptor of the result. Make sure it doesn't overlap with z and y. HTH Thomas |
06-22-2015, 11:38 PM
(This post was last modified: 06-23-2015 12:09 AM by Marcio.)
RE: [WP 34s] Matrix multiplication procedure | |||
