(50G) Elliptic Curve Integer Factorization Programme
06-25-2015, 07:49 AM (This post was last modified: 06-15-2017 01:41 PM by Gene.)
While I am convinced that people are not supposed to live more than 50 years I'm still jogging on at the age of 62, so I decided to write a large(ish) programme.
The programme ecm takes a composite integer as input & returns a factor, found through the elliptic curve factorzing method.
ecm, while itself a short programme, has several sub-programmes integral to its functioning, as is my heart to my body, which qualify ecm to receive the attribute large
ecm
  CK1&Dispatch
  # FF
    ID x00E
    Z100_
    ID x00D
x008
  BINT0
  4UNROLL
  NULLLAM
  BINT5
  NDUPN
  DOBIND
  NULL{}
  3GETLAM
  Z1_
  FPTR2 ^QSub
  FPTR2 ^Z>R
  % 999999999999.
  %MIN
  %RAN
  %IP
  FPTR2 ^R>Z
  1GETLAM
  FPTR2 ^Z2BIN
  ZERO_DO
  INDEX@
  DUP
  BINT80h
  #1+
  "Mul #: "
  SWAP&$
  BIGDISPROW2
  DROP
  FPTR2 ^#>Z
  DUP
  ZINT 128
  FPTR2 ^QAdd
  1GETLAM
  FPTR2 ^ZNMin
  DUP4PUTLAM
  ID x00A
  5GETLAM
  3UNROLL
  2GETLAM
  3GETLAM
  ID x009
  IT
    ExitAtLOOP
    DUP
    Z1_
    Z>
    OVER
    3GETLAM
    Z<
    AND
    NOT?SEMI
    5GETLAM
    2GETLAM
    4GETLAM
    BINT3
    {}N
    SWAP
  BINT80h
  +LOOP
  ABND
  OVER
  NULLCOMP?
  case2drop
  Z0_
  ROTDROP
x009
  ROT
  FPTR2 ^DupQIsZero?
  case
    4UNROLL3DROP
    TRUE
  FPTR2 ^Z>ZH
  5UNROLL
  3PICK
  Z1_
  5PICK
  DUPDUP
  FPTR2 ^RMULText
  8PICK
  FPTR2 ^RADDext
  FPTR2 ^RMULText
  5ROLL
  FPTR2 ^RADDext
  4PICK
  FPTR2 ^ZMod
  DUP
  5PICK
  ID x00F
  ROTDUP
  FPTR2 ^ZIsOne?
  NOTcase
    10UNROLL
    BINT9
    NDROP
    TRUE
  2DROP
  NULLLAM
  BINT7
  NDUPN
  DOBIND
  FALSE
  SWAP
  FPTR2 ^ZBits
  ONE_DO
    3GETLAM
    DUP
    FPTR2 ^QAdd
    5GETLAM
    ID x00F
    ROTDUP
    FPTR2 ^ZIsOne?
    NOTcase
      5UNROLL
      3DROPTRUE_
      ExitAtLOOP
    2DROP
    Z3_
    6GETLAM
    FPTR2 ^ZSQ_
    FPTR2 ^RMULText
    7GETLAM
    FPTR2 ^QAdd
    1GETLAM
    FPTR2 ^QMul
    FPTR2 ^QMul
    5GETLAM
    FPTR2 ^ZMod
    DUP
    FPTR2 ^ZSQ_
    2GETLAM
    FPTR2 ^QMul
    6GETLAM
    DUP
    FPTR2 ^QAdd
    FPTR2 ^QSub
    5GETLAM
    FPTR2 ^ZMod
    6GETLAM
    OVER
    6PUTLAM
    FPTR2 ^RSUBext
    FPTR2 ^QMul
    3GETLAM
    FPTR2 ^RNEGext
    FPTR2 ^SWAPRSUB
    5GETLAM
    FPTR2 ^ZMod
    3PUTLAM
    ISTOP-INDEX
    #1-
    FPTR2 ^ZBit?
    NOT?SEMI
    6GETLAM
    4GETLAM
    FPTR2 ^QSub
    5GETLAM
    ID x00F
    ROTDUP
    FPTR2 ^ZIsOne?
    NOTcase
      5UNROLL
      3DROPTRUE_
      ExitAtLOOP
    2DROP
    Z-1_
    3GETLAM
    Z1_
    FPTR2 ^QSub
    ROT
    FPTR2 ^QMul
    5GETLAM
    FPTR2 ^ZMod
    DUPDUP
    FPTR2 ^QMul
    2GETLAM
    FPTR2 ^QMul
    6GETLAM
    FPTR2 ^QSub
    4GETLAM
    FPTR2 ^QSub
    5GETLAM
    FPTR2 ^ZMod
    DUP
    6PUTLAM
    4GETLAM
    FPTR2 ^QSub
    FPTR2 ^QMul
    FPTR2 ^QSub
    5GETLAM
    FPTR2 ^ZMod
    3PUTLAM
  LOOP
  SWAPDROPDUP
  ?SKIP
    6GETLAM
    SWAP
  ABND
x00A
  Z1_
  OVER
  ID x00C
  4PICK
  ID x00C
  Z1_
  FPTR2 ^QAdd
  Z2_
  FPTR2 ^ZNMax
    2DUP
    Z<
    case
    COLA_EVAL
      DUP
      4ROLL
      FPTR2 ^RMULText
      3UNROLL
      Z1_
      FPTR2 ^RADDext
    AGAIN
  2DROP
  SWAPROT
  Z2_
  FPTR2 ^ZNMax
    FPTR2 ^Prime+
    2DUP
    Z<
    case
    COLA_EVAL
      DUP
      4ROLL
      FPTR2 ^RMULText
      3UNROLL
    AGAIN
  2DROP
x00B
  %ABS
  %3
  %MAX
  %LN
  DUP
  %LN
  %SQRT
  %EXP
x00C
  DUP
  Z2_
  Z<
  ?SEMI
  Z2_
  OVER
  FPTR2 ^Z>ZH
  FPTR2 ^ZBits
  SWAPDROP
  #2/
  #1+
  FPTR2 ^RP#
  ZEROSWAP
  SWAPDROPDUP
  3PICKOVER
  FPTR2 ^ZDIVext
  DROP
  FPTR2 ^QAdd
  Z2_
  FPTR2 ^ZDIVext
  DROP
  2DUP
  Z>
  NOT_UNTIL
  DROPSWAPDROP
x00D
  FPTR2 ^3LAMBIND
  Z0_
  1GETLAM
  FPTR2 ^Z2BIN
  #1+_ONE_DO
  "Curve #: "
  INDEX@
  BIGDISPROW3
  3GETLAM
  BINT2
  ZERO_DO
  %RAN
  % 999999999999.
  %IP
  FPTR2 ^R>Z
  OVER
  FPTR2 ^ZMod
  SWAPLOOP
  3UNROLL
  ZINT 27
  OVER
  BINT2
  FPTR2 ^RP#
  FPTR2 ^QMul
  Z4_
  4PICK
  BINT3
  FPTR2 ^RP#
  FPTR2 ^RMULText
  FPTR2 ^QAdd
  4PICK
  FPTR2 ^ZGcd
  FPTR2 ^DupZIsOne?
  ITE
    DROPSWAP
    3UNROLL
    2GETLAM
    ID x008
    DUP
    Z1_
    Z>
    OVER
    3GETLAM
    Z<
    ANDcase
    ExitAtLOOP
    DROP
    ROTROT2DROP
    ExitAtLOOP
  LOOP
  ABND
  FPTR2 ^DupQIsZero?
  ?SEMI
  ROTDROP
x00E
  DUP
  FPTR2 ^Z>R
  ID x00B
  %2
  %SQRT
  %NROOT
  %CEIL
  FPTR2 ^R>Z
x00F
  BINT0
  3UNROLL
  ROT#1+UNROT
  DUPUNROT
  FPTR2 ^ZDIVext
  SWAP
  4UNROLLDUP
  Z0_
  EQUAL
  UNTIL
  DROP
  ZINT1_0_
  4ROLL
  ZERO_DO
  DUPUNROT
  5ROLL
  FPTR2 ^QMul
  FPTR2 ^QSub
  LOOP
  3PICK
  FPTR2 ^ZIsNeg?
  NOT?SEMI
  BINT3
  ZERO_DO
  ROT
  FPTR 6 4FB
  LOOP
07-04-2015, 05:46 AM
RE: HP 50G: Elliptic Curve Integer Factorization Programme
Here the results of some factorizations of semi-primes composed of two factors with approx the same number of digits on emu48 on my computer, processor Intel(R) Core(TM) i7-4790 CPU @3.60 GHz, 4 Core, 8 logical processors.
First column is log to base 10 of input, second is time required to factorize in seconds.
The stats return a correlation coefficient of
0.6106
for the best fit of
T = 2.6759E-8*X^7.4441.
Conclusion: If no one, not even you, can come up with improvements or programme some part, especially IEGCD, in machine language, the programme is hopelessly slow.
18.0146 79.807
18.8923 98.5524
18.8975 10.0884
19.3222 36.252
19.4054 274.8845
19.4084 85.2894
19.4254 441.4695
19.6145 179.0726
19.7376 238.6617
19.8716 129.8376
20.4267 402.8607
21.2936 107.4248
21.3072 22.8505
21.3146 1662.9108
21.4127 60.436
21.425 222.3395
21.5316 42.5278
21.6174 60.3276
21.6857 192.4299
21.7322 182.1733
22.8705 57.5834
23.0025 540.8728
23.0466 730.3448
23.2181 504.7317
23.219 282.411
23.3225 1180.345
23.5486 996.9871
23.8556 5.2686
23.8902 524.1971
23.9313 5568.984
23.9404 1163.9684
24.0769 1983.0992
24.3113 1565.413
24.3773 1368.266
25.1759 3049.3097
25.3486 927.7865
25.8893 1080.844
26.33 3898.1266
26.9381 5411.0289
27.4156 304.9012
27.6004 477.2427
27.6311 1142.7007
27.7274 402.4984
28.0436 7964.2211
28.6526 493.1255
28.7634 5552.1494
28.8949 6964.2645
29.022 1977.3912
29.1465 18679.9346
29.3683 5317.1396
29.3936 2975.8624
29.4633 2270.5417
29.4973 5707.9138
29.5137 586.6985
29.5154 142.7861
29.5888 18.1981
29.6677 19448.0819
29.6937 6542.9614
30.8504 20809.2253
31.6527 317.5496
