[WP 34s] Trouble finding root - (solved)
06-29-2015, 01:09 AM (This post was last modified: 06-29-2015 01:19 AM by Marcio.)
Hello all,
I am having troubles finding the root of the following equation:
\[0.05=\frac{x\times coth(x) - 1}{10x\times coth(10x) - 1}\]
to which I created the following program:
LBL 01
#10
ENTER
TANH
1
x<>y
ENTER
TANH
1
x<>y
#005
#100
END
1
5
SLV 01
The 34s will complain there is a domain error.
Hope I am missing something.
Thanks
Marcio
EDIT: Found the error. Problem solved!
06-29-2015, 07:37 AM
RE: [WP 34s] Trouble finding root - (solved)
(06-29-2015 01:09 AM)Marcio Wrote:  EDIT: Found the error. Problem solved!
It would be interesting for others to know what went wrong and how you fixed it.
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
06-29-2015, 11:06 AM (This post was last modified: 06-29-2015 11:11 AM by RMollov.)
(06-29-2015 01:09 AM)Marcio Wrote:  Hello all,
LBL 01
#10
ENTER
TANH
1
x<>y
ENTER
TANH
1
x<>y
#005
#100
END
1
5
SLV 01
Thanks
Marcio
You could save a few steps:
LBL 01
XEQ 00
X<>Y
SDL 001
ENTER
XEQ 00
#005
SDR002
RTN
LBL 00
TANH
1
END
06-29-2015, 11:13 AM
The 34s complained because the first guess I entered was zero.
06-29-2015, 11:23 AM
(06-29-2015 11:06 AM)RMollov Wrote:  You could save a few steps:
LBL 01
XEQ 00
X<>Y
SDL 001
ENTER
XEQ 00
#005
SDR002
RTN
LBL 00
TANH
1
END
Yes, much shorter. Thanks.
06-29-2015, 06:59 PM (This post was last modified: 06-29-2015 07:05 PM by Dieter.)
(06-29-2015 11:23 AM)Marcio Wrote:  Yes, much shorter. Thanks.
Both shorter and faster, using the some special 34s features:
LBL 01
TANH
DEC X
X<> Y
SDL 001
ENTER
TANH
DEC X
#005
SDR 002
END
1 [ENTER] 5 [SLV] 01
=> 1,64561382716
Dieter
06-29-2015, 07:20 PM
Indeed. Faster than the solver of the 35s too.
08-05-2015, 01:40 AM (This post was last modified: 08-05-2015 01:44 AM by Marcio.)
LBL 1
1
0
ENTER
TANH
1
x<>y
ENTER
TANH
1
x<>y
0
0
5
END
Gentlemen,
I have been trying to solve this equation for X using the 15C but it is not working.
Anyway, the code above will make the 15C output 0.0389, which is not correct. Could you identify what I am missing here?
Please note that there has been no attempt to optimize the given code.
Very much appreciated.
Marcio
08-05-2015, 03:48 AM
Marcio Wrote:  Could you identify what I am missing here?
Just remove the last "/", before the "-".
08-05-2015, 04:03 AM
Oh yes, I forgot to remove that extra /. Thanks.
