MSGBOX with OK_Cancel
06-29-2015, 10:08 AM
hi,
what's the correct syntax for MSGBOX() with OK, Cancel keys?
With
ch:= MSGBOX("Another calculation?", OK_Cancel);
IF (ch<>0)  THEN changeData(); END;
I get syntax error...
Thanks!
Salvo
06-29-2015, 10:41 AM (This post was last modified: 06-29-2015 10:42 AM by DrD.)
RE: MSGBOX with OK_Cancel
Hi Salvo,
Use MSGBOX("Your string",1) to put Cancel and OK in the soft keys.
Use 0, to omit the Cancel soft menu item.
-Dale-
06-29-2015, 10:54 AM
(06-29-2015 10:41 AM)DrD Wrote:  Hi Salvo,
-Dale-
ok, thank you, it works!
Salvo
