Cannot assign a program to K_Cas
01-13-2014, 10:56 PM
Sorry if this has been answered already. I tried to assign a user program to K_Cas, and even if there is no Check errors, it only does its main function, that is, to set the calculator in CAS mode. KS_Cas works, but K_Cas cannot be assigned to anything I tried. Nothing in the manual prevents about the CAS key not available for user functions. Does anyone have the same problem? (Rev. 5447). Thanks and regards, Miguel |
01-14-2014, 12:21 AM
RE: Cannot assign a program to K_Cas
There are many such keys that behave this way (e.g. the [a b/c] key, the [+/-] key, to name a few) -- likely remnants of old HP 38GII behavior.
Graph 3D | QPI | SolveSys |
