Astro Lab 4 with Solar System View!
07-06-2015, 01:20 PM
(This post was last modified: 07-06-2015 02:39 PM by Marcel.)
Hi!
I update Astro Lab 4 with a new function that will compute the place of all the planets of the Solar System at the same moment. After that, a apps call "Solar System View" show you this configuration from the upside view. You can Zoom In or Zoom Out in this view. Have fun! Marcel |
07-06-2015, 03:12 PM
RE: Astro Lab 4 with Solar System View!
(07-06-2015 01:20 PM)Marcel Wrote: Hi! thank you! I can see (and I'm happy) that you're amazing programming Astronomy in the Prime, like me. Very nice ![]() Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
07-06-2015, 05:35 PM
(This post was last modified: 07-06-2015 05:38 PM by Marcel.)
Hi Salvomic!
Thank you for your reply. My last fonction was simple to program but hard to do in the Geometry apps. You must use the key and not the screen to use it because the objects are not lock, so they move if you want to move the screen. After some times, I find more simple to use only the key + and -. If you have Mathematica or Wolfram Alpha, check for "Solar system configuration now" you will have what Astro Lab display! Marcel |
07-06-2015, 06:38 PM
(07-06-2015 05:35 PM)Marcel Wrote: If you have Mathematica or Wolfram Alpha, check for I'll do soon! Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
User(s) browsing this thread:
