Request for Circular Shift Functions
07-19-2015, 07:54 PM
Could you please add Circular Shift Functions for both Lists Type and Binary Bits Type to the HP Prime and also Xcas.
These Functions would be very useful for teaching Elementary Cryptography and also Programming.
I am thinking of a fun elementary cryptography App. on HP Prime, where the teacher and students could send encrypted text to each other using basic methods like Caesar Shift and Block Codes. Then students would decode received message using supplied algorithms they learn about in Class.
See Wikipedia "Circular Shift " for more info.
Some C code to help you start:
* Shift operations in C are only defined for shift values which are
* not negative and smaller than sizeof(value) * CHAR_BIT.
Rotate Left Example:
unsigned int rotl(unsigned int value, int shift) {
return (value << shift) | (value >> (sizeof(value) * CHAR_BIT - shift));
Rotate Right Example:
unsigned int rotr(unsigned int value, int shift) {
return (value >> shift) | (value << (sizeof(value) * CHAR_BIT - shift));
Thanks !
Colm
07-20-2015, 01:00 AM
RE: Request for Circular Shift Functions
Hello Colm,
Is this what you mean?
For lists:
LOCAL s;
EXPORT listright(t)
 IF type(t)≠6 THEN RETURN ;END;
 s:=SIZE(t);
 RETURN CONCAT(t(s),SUB(t,1,s-1));
EXPORT listleft(t)
 s:=SIZE(t);
 RETURN CONCAT(SUB(t,2,s),t(1));
For bits:
EXPORT bitleft(t)
 RETURN BITSL(t,1)+BITSR(t,GETBITS(t)-1);
EXPORT bitright(t)
 RETURN BITSR(t,1)+BITSL(t,GETBITS(t)-1);
Road
07-20-2015, 06:07 AM
Yes, thank you.
Perhaps now they put functions in operating system.
Thank you
Colm [/i]
07-20-2015, 07:16 PM
Could you please put these programs in the Hp Prime Software Section.
So everyone can use in their programs.
Thank You.
Colm
User(s) browsing this thread:
