Solving a Single Congruence Equation
01-16-2014, 03:14 AM
The program solves for x in the equation:
A * x = B mod N Examples: 4 * x = 6 mod 7 A = 4, B = 6, N = 7 Solution: 5 5 * x = 3 mod 17 A = 5, B = 3, N = 17 Solution: 4 11 * x = 3 mod 16 A = 11, B = 3, N = 16 Solution: 9 HP Prime Program: CONG Code:
04-12-2014, 07:22 AM
RE: Solving a Single Congruence Equation
How long does it take to solve:
999999999998 * x = 1 mod 999999999999 Or maybe just: 999998 * x = 1 mod 999999 Kind regards Thomas PS: Ever heard of the Chinese remainder theorem? |
04-12-2014, 11:00 PM
(04-12-2014 07:22 AM)Thomas Klemm Wrote: How long does it take to solve: Returns answer of 2 instantly on an actual Prime. I guess faster than instantly on the emulator. --Bob Prosperi |
04-15-2014, 01:48 PM
(04-12-2014 11:00 PM)rprosperi Wrote: Returns answer of 2 instantly on an actual Prime. I guess faster than instantly on the emulator. Is that the answer to: 999999999998 * x = 1 mod 999999999999 ? Because that's wrong. 999999999998 * 2 = 999999999997 mod 999999999999 But that's probably due to a rounding error: \(\frac{999999999998 \times 2 - 1}{999999999999} = 1.9999999999969999999999969999999999969999999999969999...\) This will be rounded to 2.00000000000. The correct answer is of course: x = 999999999998 = -1 mod 999999999999 The 2nd example shouldn't suffer from these kind of problems though I didn't test it. Cheers Thomas |
04-15-2014, 11:31 PM
(This post was last modified: 04-15-2014 11:31 PM by Han.)
In keeping the algorithm fairly simple, I was thinking of the following adjustment. If \(A > B\) then compute \( (q,r) \in \mathbb{Z}^2 \) such that \( A = qB + r\). Then
\[ Ai - B \equiv (qB+r)i - B \equiv B (qi -1) + ri \] and let \( i \) run from \( -N/2 \) to \( N/2 \) (adjusting for even/odd \( N \) of course). Similarly, if \( B = qA + r \) then \[ Ai - B \equiv Ai - (qA+r) \equiv A (i-q) -r \] We still run into overflow issues, but I think this approach might handle a few more cases than the original approach. Also, I wonder if the MOD command would work better than division inside FP(). Graph 3D | QPI | SolveSys |
04-16-2014, 04:00 AM
(04-15-2014 11:31 PM)Han Wrote: In keeping the algorithm fairly simple Euklid's algorithm to calculate the greatest common divisor isn't that complicated. You just keep track of the multiples of A and N. ([u v] is short for: u*N + v*A) Example: 5 * x = 3 mod 17 Calculate gcd(17, 5): [1 0] 17 [0 1] 5 [1 -3] 2 = 17 - 3 * 5 [-2 7] 1 = 5 - 2 * 2 Thus gcd(17, 5) = 1 = -2 * 17 + 7 * 5 Therefore: 5 * 7 = 1 mod 17 5 * 7 * 3 = 3 mod 17 5 * 21 = 3 mod 17 5 * 4 = 3 mod 17 Cheers Thomas PS: You can ignore u. Just keep track of v. |
04-16-2014, 04:23 AM
Even simpler :-) Very nice!
04-16-2014, 07:48 AM
This program shouldn't result in an overflow:
Code: #!/usr/bin/python Cheers Thomas |
02-07-2015, 03:12 PM
(01-16-2014 03:14 AM)Eddie W. Shore Wrote: The program solves for x in the equation: I was searching a program like this Thank you, Eddie! Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
03-08-2019, 03:24 AM
It may be easier to solve A x ≡ B (mod N) problem using continued fraction.
It is the same as Euclid extended gcd method, without tracking multiples for A and N Example 5 x ≡ 3 (mod 17) 17/5 = 3 + 1/(2 + 1/2) Drop the last term, we get 3 + 1/2 = 7/2 -> 7*5 - 2*17 = 1, so 7 ≡ 1/5 (mod 17) x ≡ 3/5 ≡ 3*7 ≡ 4 (mod 17) |
03-08-2019, 07:16 PM
(This post was last modified: 03-11-2019 02:58 PM by Albert Chan.)
Getting to the "2nd best" convergents might be messy, we can do guesses.
You get to the same result even if the guesses were off. Example: With modulo N=17789, solve 12345 x ≡ 1 12345 ≡ -5444 N/5444 ≈ 3.2676 ≈ 13/4, 13*(12345 x ≡ 1) → (384 x ≡ 13) N/384 ≈ 46.3255 ≈ 139/3, 139*(384 x ≡ 13) → (9 x ≡ 1807) N/9 ≈ 1976.5555 ≈ 3953/2, 3953*(9 x ≡ 1807) → (-x ≡ 9682) → (x ≡ 8107) Warning: make sure guess scaling is co-prime to the modulo. |
03-08-2019, 11:34 PM
(This post was last modified: 03-09-2019 02:11 PM by Albert Chan.)
(03-08-2019 07:16 PM)Albert Chan Wrote: Example: solve 12345 x ≡ 1 (mod N), with N = 17789, for x For comparison, this build 17789/5444 continued fraction convergents P/Q Code: (next column) = CF * (current column) + (prev column) Q values are not needed here ... 12345 * 8107 ≡ 1 (mod N), thus x ≡ 1/12345 ≡ 8107 (mod N) Edit: it might be cheaper to do Q row instead, since Q's < ½ P's P's = round(Q's * fraction) |
03-09-2019, 02:10 PM
(This post was last modified: 03-14-2019 12:42 AM by Albert Chan.)
Since we only need 2nd best convergents (to get inverse), we can skip some intermediates.
Build CF coef with rounded of number, not the integer part. Coefficients are not really continued fraction coefficients, but it is OK The list is likely shorter, and easily built with calculator FIX-0 mode: 17789/5444 = ; show 3 1/(Ans - Rnd(Ans = ; show 4 1/(Ans - Rnd(Ans = ; show -4 ... Code: Coef 3 4 -4 5 -7 -5 -2 12345 * 8107 ≡ 1 (mod 17789) x ≡ 1/12345 ≡ 8107 (mod 17789) |
03-10-2019, 12:45 AM
(This post was last modified: 03-12-2019 12:13 PM by Albert Chan.)
Another way to do inverse is to force even coef., thus easily reduced.
(make sure mul/div factors co-prime to the modulo) Same example, solve 12345 x ≡ 1 (mod 17789) 12345 x ≡ -5444 x ≡ 1 ≡ -17788 (mod 17789) 1361 x ≡ 4447 (mod 17789) (12345 - 9*1361) x ≡ 1 - 9*4447 (mod 17789) 96 x ≡ -40022 ≡ -75600 (mod 17789) 2 x ≡ -1575 ≡ 16214 (mod 17789) x ≡ 8107 (mod 17789) If N is large, we can solve another, with smaller modulo: x ≡ (4447 - 17789 k) / 1361 (mod 17789) → 17789 k ≡ 4447 (mod 1361) 96 k ≡ 4447 ≡ 5808 (mod 1361) 2 k ≡ 121 ≡ -1240 (mod 1361) k ≡ -620 (mod 1361) x ≡ (4447 - 17789 * -620) / 1361 ≡ 8107 (mod 17789) |
03-12-2019, 03:46 AM
(This post was last modified: 10-02-2022 03:12 PM by Albert Chan.)
(03-10-2019 12:45 AM)Albert Chan Wrote: If N is large, we can solve another, with smaller modulo: Example, solve 1223334444 x ≡ 1 (mod 9988776655) List Euclid GCD intermediates, build inverses in reverse order. 9988776655 → 3171632349 1223334444 → -388432661 202101103 → 64171061 10727826 → -3406295 9000235 → 2857751 1727591 → -548544 362280 → 115031 278471 → -88420 83809 → 26611 27044 → -8587 2677 → 850 274 → -87 211 → -floor(-20/63 * 211) = 67 63 → -floor(7/22 * 63) = -20 22 → -floor(-6/19 * 22) = 7 19 → -floor(1/3 * 19) = -6 3 → 1 ; 1-1 ≡ 1 (mod 3) 1 = gcd 9988776655 * -388432661 + 1223334444 * 3171632349 = 1 → 1/9988776655 ≡ -388432661 (mod 1223334444) → 1/1223334444 ≡ 3171632349 (mod 9988776655) |
03-12-2019, 09:03 PM
(This post was last modified: 10-02-2022 02:21 PM by Albert Chan.)
There is no need to walk the whole chain of inverses.
For x ≡ 1/1223334444 (mod 9988776655), gcd intermediates are even, final inverse is positive. We can guess where it should end up. 1/3 ≡ -6 (mod 19) → x ≈ |floor(−6/19 * 9988776655)| = 3154350523 1/19 ≡ +7 (mod 22) → x ≈ |floor(+7/22 * 9988776655)| = 3178247117 x is between above limits. We can extrapolation in smaller steps, to scale to correct inverses. \(\displaystyle \left|{6 \over 19} - {7 \over 22}\right| = {1 \over 19×22} = {1 \over 418} < {1 \over 274} \) 1/211 ≡ (-1)4 floor(-6/19 * 274) ≡ -87 (mod 274) Redo previous example, skipping unneeded calculations. 9988776655 → (-1)^6 floor(115031/362280 * 9988776655) = 3171632349 1223334444 202101103 10727826 9000235 1727591 362280 → (-1)^5 floor(-87/274 * 362280) = 115031 ; 362280*1727591 ≈ 626e9 278471 83809 27044 2677 274 → (-1)^3 floor(7/22 * 274) = -87 ; 274*2677=733498 211 63 22 → (-1)^2 floor(1/3 * 22) = 7 ; 22*63=1386 19 3 → 1 ; 3*19=57 1 = gcd 4th scalings gives: 1/1223334444 ≡ 3171632349 (mod 9988776655) |
10-01-2022, 03:48 PM
(This post was last modified: 10-02-2022 03:43 PM by Albert Chan.)
CAS> c := dfc(9988776655/1223334444) → [8,6,18,1,5,4,1,3,3,10,9,1,3,2,1,6,3]
CAS> dfc2f( reverse(c) ) → 9988776655 / 3171632349 Building of inverses are equivalent to convergents of reversed continued fraction coefficients. (with alternative signs, starting from 1-1 ≡ +1 (mod m)) 9988776655 8 *388432661+64171061 = 3171632349 1223334444 6 *64171061+3406295 = 388432661 - 202101103 18 *3406295+2857751 = 64171061 10727826 1 *2857751+548544 = 3406295 - 9000235 5 *548544+115031 = 2857751 1727591 4 *115031+88420 = 548544 - 362280 1 *88420+26611 = 115031 278471 3 *26611+8587 = 88420 - 83809 3 *8587+850 = 26611 27044 10 *850+87 = 8587 - 2677 9 *87+67 = 850 274 1 *67+20 = 87 - 211 3 *20+7 = 67 63 2 *7+6 = 20 - 22 1 *6+1 = 7 19 6 *1+0 = 6 - 3 1 1 = gcd |
