(49G) Prime Counting Programme
08-02-2015, 08:55 AM
(This post was last modified: 06-15-2017 01:41 PM by Gene.)
For integer input the programme returns the number of prime numbers up to & including the input.
eg For input 5 the programme returns 3. Maximum input is 1680, higher values produce an error. Code:
08-03-2015, 03:22 PM
RE: HP 49G: Prime Counting Programme
An APPROXIMATE solution to the prime count question is given by Locker-Ernst's formula
p(n) ≈ n / ( H(n) - 3 / 2 ) H(n) the nth harmonic number. In the programme below the harmonic number function is replaced by the HP 49G function Psi(n) (FPTR 7 11E is the Psi function for long reals), as Psi(n+1)+gamma gives H(n). Code:
