Max 71B Memory Using FRAM71
08-21-2015, 05:36 AM
Maximum 71B Soft-Configured RAM Using FRAM71
Referring to the S/W IDS, Ch. 2 and 3
1. The memory available for soft-configured devices is the address range 30000-FFC00.
2. If a hard-coded module is installed, E0000-FFC00 will not be available for soft-configured devices.
1. Max RAM
The address range above provides 425472 bytes of RAM. Using 32 and 8K devices, 408K can be configured using the string "939495969798999A9B9C9D9EBF000000".
Port Dev Size Addr  Type
0     0    4  F4000  0
0     1    4  F6000  0
0     2    4  F8000  0
0     3    4  FA000  0
5     0    32 30000  0
5     1    32 40000  0
5     2    32 50000  0
5     3    32 60000  0
5     4    32 70000  0
5     5    32 80000  0
5     6    32 90000  0
5     7    32 A0000  0
5     8    32 B0000  0
5     9    32 C0000  0
5     A    32 D0000  0
5     B    32 E0000  0
5     C     8 F0000  0
2. Max RAM with HP-IL
400K of memory can be utilized using the string "939495969798999A9B9C9DAE00000000".
  0   0    4  E8000  0
  0   1    4  EA000  0
  0   2    4  EC000  0
  0   3    4  EE000  0
  5   0   32  30000  0
  5   1   32  40000  0
  5   2   32  50000  0
  5   3   32  60000  0
  5   4   32  70000  0
  5   5   32  80000  0
  5   6   32  90000  0
  5   7   32  A0000  0
  5   8   32  B0000  0
  5   9   32  C0000  0
  5   A   32  D0000  0
  5   B   16  E0000  0
  0   5   16  F0000  2  HP-IL
384K of RAM is configured from 30000-EFFFF. Plug-In ROM's and IRAM's always begin configuration on a 32K boundary, so the HP-IL ROM is at F0000.
3. FORTH/Assembler ROM installed, no HP-IL
336K of memory can be utilized using the string "939495969798999A9BAC000000000000".
  0   0    4  C8000  0
  0   1    4  CA000  0
  0   2    4  CC000  0
  0   3    4  CE000  0
  5   0   32  30000  0
  5   1   32  40000  0
  5   2   32  50000  0
  5   3   32  60000  0
  5   4   32  70000  0
  5   5   32  80000  0
  5   6   32  90000  0
  5   7   32  A0000  0
  5   8   32  B0000  0
  5   9   16  C0000  0
  1   0   16  D0000  2  FORTH
The high two pages of memory aren't available because of the hard-coded module. The FORTH ROM is configured at D0000. That leaves 320K for RAM.
4. FORTH/Assembler and HP-IL installed.
352K of memory can be utilized using the same config string as in 3., "939495969798999A9BAC000000000000".
  0   0    4  C8000  0
  0   1    4  CA000  0
  0   2    4  CC000  0
  0   3    4  CE000  0
  5   0   32  30000  0
  5   1   32  40000  0
  5   2   32  50000  0
  5   3   32  60000  0
  5   4   32  70000  0
  5   5   32  80000  0
  5   6   32  90000  0
  5   7   32  A0000  0
  5   8   32  B0000  0
  5   9   16  C0000  0
  0   5   16  D0000  2  HPIL
  1   0   16  D8000  2  FORTH
320K is available for RAM.
I would appreciate it if someone would verify my findings.
Dave
08-21-2015, 04:54 PM (This post was last modified: 08-21-2015 05:31 PM by Hans Brueggemann.)
RE: Max 71B Memory Using FRAM71
my findings on a 1BBBB w/ FRAM71 V511 are as follows:
(MEM values after MEMORY LOST, FORTH not initialized)
1. MAX RAM, no modules
418252, 408 KB RAM
2. MAX RAM, w/IL
393708, 384 KB RAM
3. MAX RAM, FORTH
93E495969798999A9B9C9DAE (93 is HC, E4 is SC ROM for FORTH)
328168, 320 KB RAM
4. MAX RAM, IL, FORTH
328149, 320 KB RAM
hans
08-21-2015, 05:28 PM (This post was last modified: 08-21-2015 05:33 PM by Dave Frederickson.)
(08-21-2015 04:54 PM)Hans Brueggemann Wrote:  3. MAX RAM, FORTH
93D495969798999A9B9C9DAE (93 is HC, D4 is SC ROM for FORTH)
328168, 320 KB RAM
93D495969798999A9B9CAD (93 is HC, D4 is SC ROM for FORTH)
295368, 288 KB RAM
hans
In Case 4, FRAM71 isn't being used for ROM as I was trying to determine the maximum allowable RAM. A physical module was used in my tests.
In Case 3, bonus points if you configured a 16K IRAM at D8000.
Dave
08-21-2015, 05:47 PM
apologies, obviously edited my post without seeing your response... i reconfigured case 3 and 4 to E4 instead of D4, which makes results more comparable (and makes more sense anyway).
hans
(thanks for the bonus offer, will look into it after returning from vacation...)
