Emulator: is Copy/Paste accessible?
08-29-2015, 03:08 PM
The pdf describes using Shift/Copy to cut and paste code between programs within the App.
Is this data in a private space within the emulator, or should it be accessible from the OS clipboard (for posting here, importing to a Quickoffice document, etc )? So far whatever I have cut in a Android might be filling my phones memory, but it can't be seen Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
08-29-2015, 03:38 PM
RE: Emulator: is Copy/Paste accessible?
If you enter something on the command line, then select [Shift] [View], and from the soft menu choices select [All], type [cntrl] [C], the command line info will then be available to paste elsewhere.
08-29-2015, 06:18 PM
(08-29-2015 03:38 PM)DrD Wrote: If you enter something on the command line, then select [Shift] [View], and from the soft menu choices select [All], type [cntrl] [C], the command line info will then be available to paste elsewhere. That suggests to me that the PC version uses a shared clipboard, if I understand you correctly. On the Android it seems different: after cutting some text in SMS, then subsequently Shift/Copying a program: Both pasting in SMS and pasting in Quick-office restore the cut SMS text. Wherever the program has been cut to, it is clearly not accessible! I haven't tried it yet, but I suspect importing a library program is also unlikely to work using this method. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
08-29-2015, 06:44 PM
i can now confirm that Shift/Paste shows some App stuff, NOT the SMS text that can still be pasted outside the a App.
So using Shift/Copy to copy a program here or Shift/Paste to copy a program from here does not seem a useful approach. In the 1980s typing in BASIC programs from listings used to be a popular pastime. :-( Computers weren't as portable then but at least they used to have a QWERTY keyboard. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
08-30-2015, 01:34 AM
(This post was last modified: 08-30-2015 01:34 AM by Tim Wessman.)
(08-29-2015 06:44 PM)StephenG1CMZ Wrote: So using Shift/Copy to copy a program here or Shift/Paste to copy a program from here does not seem a useful approach. The system clipboard is accessed in the slideout menu from the right. I know there is a paste there, but not certain if there is also a "copy". The copy on the VIEW button is only for the application and does not tie in to the system clipboard. TW Although I work for HP, the views and opinions I post here are my own. |
08-30-2015, 08:25 AM
(08-30-2015 01:34 AM)Tim Wessman Wrote:(08-29-2015 06:44 PM)StephenG1CMZ Wrote: So using Shift/Copy to copy a program here or Shift/Paste to copy a program from here does not seem a useful approach. Thanks for that. When I first glanced at that it didn't seem useful, but I had another go and it works. There is a Copy and a Paste. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
