Pascal's triangle
09-01-2015, 01:11 PM (This post was last modified: 09-01-2015 01:36 PM by roadrunner.)
Pascal's triangle
Function pascal(x) returns a level of Pascal's triangle.
Example:
pascal(7) returns {1,7,21,35,35,21,7,1}
the 7th level of Pascal's triangle
#pragma mode(separator(.,;) integer(h32))
EXPORT pascal(x)
 case
  if x < 1 then {1};end;
  if x < 2 then {1,1}; end;
 default
  concat(1,execon("&1+&2",pascal(x−1)),1);
 end;
09-01-2015, 04:30 PM
RE: Pascal's triangle
Isn't {1,7,21,35,35,21,7,1} the 8th line?
09-02-2015, 01:15 AM
(09-01-2015 04:30 PM)Gerald H Wrote:  Isn't {1,7,21,35,35,21,7,1} the 8th line?
Here: http://ptri1.tripod.com/ they start counting with row zero, making {1,7,21,35,35,21,7,1} row 7. But Blaise Pascal himself, it seems, would have agreed with you: https://en.wikipedia.org/wiki/Pascal%27s...Pascal.jpg
-road
09-02-2015, 02:58 PM
Alternative method, using a single expression:
pcoeff(makemat(-1,j,1)) --> jth row of Pascal's Triangle
Works both in Home and CAS.
<0|ɸ|0>
-Joe-
User(s) browsing this thread:
