Variable e not usable for local-variable
09-01-2015, 10:01 PM
The program mentioned in the other thread needed some local variables, as I am lazy I usually take short names and came up with e, as it should hold the result of euler(n), the editor refused to take it. So I used the cas to find out that e cannot be taken as a variable at all although I think to have read that all small letters are available. That is not very serious but can be changed if the system used another symbol, perhaps a fat printed e, for 2.718..., just like it does with i.
Maybe more meaningful error messages, especially in cas-programs where no debugger is available would be helpful, too. Errors like this take more time to find than writing the whole program. Arno |
09-02-2015, 03:22 AM
RE: Variable e not usable for local-variable
(09-01-2015 10:01 PM)Arno K Wrote: The program mentioned in the other thread needed some local variables, as I am lazy I usually take short names and came up with e, as it should hold the result of euler(n), the editor refused to take it. So I used the cas to find out that e cannot be taken as a variable at all although I think to have read that all small letters are available. Neither e nor i can be used as variables in Home or in CAS. (09-01-2015 10:01 PM)Arno K Wrote: That is not very serious but can be changed if the system used another symbol, perhaps a fat printed e, for 2.718..., just like it does with i. Even though i is often displayed as a stylized i, it can be keyed in by the user as a plain i, so i must still remain a reserved PPL word. So even if they started calling e "e", it wouldn't stop e from being a reserved PPL word. <0|ΙΈ|0> -Joe- |
09-02-2015, 08:12 AM
(09-02-2015 03:22 AM)Joe Horn Wrote:(09-01-2015 10:01 PM)Arno K Wrote: The program mentioned in the other thread needed some local variables, as I am lazy I usually take short names and came up with e, as it should hold the result of euler(n), the editor refused to take it. So I used the cas to find out that e cannot be taken as a variable at all although I think to have read that all small letters are available. Well, that is correct and perhaps ok, but contrary to e i can be used as a local variable and this is what I am interested in. Arno |
