Strange result from WP 31S
09-02-2015, 07:25 AM
If I try to calculate 0.0001 ^ 0.0001 using the y^x function I get 0.9990.. as answer.
Using 0.0001 x 0.0001 gives the correct answer 0.0000001. Resetting the calculator gave the the same result. Anyone having the same problem ? |
09-02-2015, 07:45 AM
RE: Strange result from WP 31S
There is no issue with WP31S.
The result is correct (at least for the real root). If you have no other calc available, you may check it There. 0.0001 ^ 0.0001 returns the 1000th root of 0.0001 0.0001 * 0.0001 is equivalent to 0.0001 ^ 2 |
09-02-2015, 08:04 AM
Thanks jch.
Back on track again. |
