Are STRINGFROMID numbers likely to change?
09-02-2015, 07:51 AM
As I understand STRINGFROMID strings vary with language selected, I was thinking they might be useful for internationalization of program text.
So how likely is it that everyone else has the same list? Is there a way of checking whether a program is running on an old system with numbers missing or even swapped? Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-02-2015, 11:03 AM
RE: Are STRINGFROMID numbers likely to change?
Bonjour
J'ai eu la même idée que vous, mais effectivement d'une version à l'autre des chaînes sont ajoutées et d'autre voient leur n° modifié. Pour savoir sur quel version nous sommes il y a la fonction VERSION -> "Calculatrice graphique HP PrimeVersion du logiciel: 2015 6 17(8151)........................." Hello I had the same idea as you, but actually from one version to the other strings are added and else have their n° modified . To know which version of us there is the function VERSION -> " HP Prime Graphing CalculatorSoftware Version : 2015 6 17 (8151) ......................... " Sorry for my english |
09-02-2015, 03:31 PM
Yes - plan on them changing N at least one more time! After that, it should remain constant. I can't provide any more information for now. TW Although I work for HP, the views and opinions I post here are my own. |
