CAS, negative numbers, and ROUND
09-14-2015, 02:07 AM
This doesn't look right, when compared to ROUND() in Home.
Firmware 8151.
09-14-2015, 12:06 PM
RE: CAS, negative numbers, and ROUND
Xcas does the same thing:
I have no point or conclusion, however, just Xcas does the same thing.
-road
09-14-2015, 04:53 PM (This post was last modified: 09-14-2015 05:18 PM by Helge Gabert.)
Seems like one has to add 1 in order to get the correct result (assuming rounding to 0 significant digits is desired).
Take -0.2:
ROUND(-0.2) should result in -0.2.
ROUND(-0.2,0) should result in 0.
ROUND(-0.2,1) should result in -0.2
ROUND(-0.2,2) should result in -0.2
ROUND(-0.2,3) should result in -0.2
And that is what Home shows, but not CAS.
User(s) browsing this thread:
