Can INPUT input what is typed
09-14-2015, 05:28 PM
(This post was last modified: 09-14-2015 05:30 PM by StephenG1CMZ.)
I have been trying to use INPUT to input search strings for my Z EDITOR program.
But the Prime seems to parse some inputs without passing them straight to the user program. For example, if you type in a single bracket, INPUT shows a pair. This happens whether you enter a bracket by using the () key, then cursor right and delete left. Or by using Shift/Chars and then selecting a single bracket. Is there a way to avoid this, so that I could search for "WAIT(" for example, rather than "WAIT()" BUT NOT "WAIT(1"?. Code:
Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-14-2015, 05:46 PM
RE: Can INPUT input what is typed
Have you tried to limit the input to Strings only?
My website: erwin.ried.cl |
09-14-2015, 06:37 PM
(09-14-2015 05:46 PM)eried Wrote: Have you tried to limit the input to Strings only? I'd tried print(string(in... Gives a pair of brackets within an extra pair of quotes. But if the user types the quotes himself: "()" then deletes a ) The program sees: ""("" At last there is a single bracket - now The problem is the extra pair of quotes. Also, I don't really want the user to have to type in the quotes - switching between in and out of Alpha should be enough. And for simple searches like WAIT without any brackets, the quotes are not necessary. Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-14-2015, 06:45 PM
The help says that you could define String as the var type and the quotes will be hidden. It seems to be what you need but I don't know how that works. I just get error.
09-14-2015, 08:34 PM
If I simply type in "WAIT" with quotes instead of just WAIT, into my existing program, the quotes are included in the match - and no match results. I'll think some more about the syntax.
