Parsing expressions
09-15-2015, 06:11 AM
Parsing expressions
Hello
I wanted to explode expression like X^2 + 5 to the list of {operation,firstOP,secondOP}, i found i can do it in CAS window with "at" special syntax like 'X^2+5'[1 +-].
It rewrites it as at('X^2+5',0) and gives answer _x -> _x (looks like lambda).
'X^2+5'[2 +-] gives x^2
'X^2+5'[3 +-] gives 5
There is no really 'at' function and this code does not work in program.
So, question is: how to parse expressions ? If there some command like OBJ-> from 50g ?
Many many thanks anyway!
XSet
09-15-2015, 07:20 AM
RE: Parsing expressions
In CAS mode you can use part():
The following CAS program could be a starting point for what you want:
#cas
OBJ(f):=
  LOCAL k,l;
  l:={};
  FOR k FROM 0 TO part(f) DO
   l:=CONCAT(l,part(f,k));
  return l;
#end
09-15-2015, 07:27 AM (This post was last modified: 09-15-2015 07:42 AM by xset.)
(09-15-2015 07:20 AM)Didier Lachieze Wrote:  In CAS mode you can use part():
OMG! What a beautiful syntax, kinda functional!
Thank you! You are Wizard !
09-26-2015, 05:44 PM
Cmd line works but obj just returns 0.
on android prime emulator.
I work with android Prime only for now on my
Galaxy Tab Pro/Note 2
09-26-2015, 06:55 PM
(09-26-2015 05:44 PM)ji3m Wrote:  Cmd line works but obj just returns 0.
The android emu is basically equivalent at this moment to the version from dec 2014. The "part" command was added in 2015 I believe.
TW
09-27-2015, 07:42 AM
Thanks GOD i did not buy Android version
