Acces to a list
09-20-2015, 06:56 PM
Acces to a list
Hi all,
Need some help with my list.
L1 ={{1,2,3},{4,5,6},{8,9,1},{7,6,1}}
1. How to calculate the amount of elements (4)?
2. How to access every separate element of list L1
Thanks, for any help!
Jan
09-21-2015, 12:39 AM
RE: Acces to a list
1. SIZE
2. L1(<number>) to access further down inside, L1(<number>,<number>...) Ex: L1(2,3) returns 6 in your given list.
TW
09-21-2015, 05:54 AM
RE: Acces to a list
Var[n] refers to:
if var is a list: the nth element of the list
if var is a string, the nth char of the string
if var is a vector, the nth element of the vector
if var is a matrix, the nth line of the matrix, or if n<0, the nth column
if var is an int, the nth bit of the int.
This works both in RCL and STO
var[n, m] refers to:
if var is a list: var[m] for the nth element of the list (parameter list can be up to 16 long!)
if var is a string, m chars starting at index n in the string
if var is a matrix, the element at pos n,mx
if var is an int, the m bit starting at pos n from the int
list(0):=val: adds at the end of the list
That should get you started.
Cyrille
