(49G) Integer Square Detection
10-11-2015, 06:48 AM
(This post was last modified: 06-15-2017 01:45 PM by Gene.)
The programme ISSQ? economically detects whether an integer is a perfect square, returning 1. for yes, 0. for no.
A problem arises in compiling the programme: the ZINTs in bold type have been processed through the command FPTR2 ^Z>ZH & are in fact hexadecimal ZINTs - the on-calculator compiler attempts to return the four numbers as decimal ZINTs, thus debilitating the programme. Similarly, the decompiler produces the programme as here printed, not indicating the hexadecimal nature of the ZINTs. Anyone have a solution to this compilation problem? ISSQ? :: CK1&Dispatch # FF :: :: 1LAMBIND TRUE ZINT 23; ZINT 11 ZINT 1218:019866014613 ZINT 65 ZINT 402483012450293 ZINT 63 ZINT 202021202030213 ZINT 64 BINT5 ONE_DO :: 1GETLAMSWAP_ FPTR2 ^ZMod FPTR2 ^Z># FPTR2 ^ZBit? SWAPDROP ?SEMI ISTOP-INDEX #2* #1- NDROP FALSE ExitAtLOOP ; LOOP 1GETABND SWAP NOTcsdrpfls :: DUP Z2_ Z< DUP ?SEMI DROPDUP FPTR2 ^Z>ZH FPTR2 ^ZBits BINT2 #/ #+ Z2_ SWAP FPTR2 ^PPow# BEGIN SWAPDROPDUP 3PICKOVER FPTR2 ^ZQUOText FPTR2 ^QAdd Z2_ FPTR2 ^ZQUOText 2DUP Z> NOT_UNTIL DROPDUP FPTR2 ^ZSQ_ ROT EQUAL ; SWAPDROP ; COERCEFLAG ; ; |
10-12-2015, 09:41 AM
RE: HP 49G: Integer Square Detection
(10-11-2015 06:48 AM)Gerald H Wrote: A problem arises in compiling the programme: the ZINTs in bold type have been processed through the command Perhaps you can replace those lines with NIBHEX statements. Not human-readable, but at least they would compile correctly. Example: Running ZINT 123 through Z>ZH returns the hex zint 7B which is displayed as "7;" by the HP 50g. This can be encoded in a program listing as: NIBHEX 4162080000B70 <0|ΙΈ|0> -Joe- |
10-12-2015, 11:53 AM
Thank you Joe, yes that works,
:: FPTR2 ^Z>ZH x->H "NIBHEX " SWAP&$ ; will then compile correctly. The decompilation problem remains - should any programme maintenance be needed the problem recurs. The problem could be obviated by putting the decimal ZINT in the programme followed by FPTR2 ^Z>ZH - it's just I find that an inelegant solution. |
10-12-2015, 12:08 PM
So here a compilable version of ISSQ?
10-13-2015, 07:04 AM
And here a slightly optimized version of ISSQ?
