PIXON with alpha channel support
09-27-2015, 03:49 PM
I need semi transparent pixels and I know that I can do workaround using RECT/RECT_P, but in this case it is really slow. I need something little faster and I'm sure that adding alpha channel support to the current PIXON/PIXON_P functions will be sufficient. Can I ask for this functionality in the next firmware release? BR, Piotr |
09-27-2015, 04:16 PM
(This post was last modified: 09-27-2015 04:22 PM by Tim Wessman.)
RE: PIXON with alpha channel support
I'll put it on the list. Note that I can't promise anything regarding any specific release, or even that there will be any more releases, but I've entered it in. There is some general cleanup in the drawing routines to bring a bit more consistency in a few places that I'd like to get done as well...
09-27-2015, 08:01 PM
Can you post an example why you need alpha support? You can create a workaround reading the pixel first
My website: ried.cl |
09-28-2015, 05:34 AM
You can use RECT which does handle alpha blending. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
09-28-2015, 07:51 AM
(This post was last modified: 09-28-2015 07:51 AM by Martin Hepperle.)
(09-27-2015 04:16 PM)Tim Wessman Wrote: I'll put it on the list. Note that I can't promise anything regarding any specific release, or even that there will be any more releases, but I've entered it in. There is some general cleanup in the drawing routines to bring a bit more consistency in a few places that I'd like to get done as well... Tim, RE: cleaning up: .. it would be nice to have the G argument in the parameter lists always in the same position (e.g. the first argument should be the Grob to draw on)... (maybe this can be done without breaking old code by checking the parameter types) Martin |
09-28-2015, 09:06 AM
(09-28-2015 05:34 AM)cyrille de brébisson Wrote: You can use RECT which does handle alpha blending. As I said in my first post I know it and I used it in my program, but it is very slow. PIXON is very fast and I hope that it will be much quicker than RECT for single pixels. Of course, even better would be to get the BLIT with alpha blending BR, Piotr |
09-28-2015, 01:00 PM
(09-28-2015 07:51 AM)Martin Hepperle Wrote: .. it would be nice to have the G argument in the parameter lists always in the same position (e.g. the first argument should be the Grob to draw on)... (maybe this can be done without breaking old code by checking the parameter types) I thought that one was already consistent. Which commands are you thinking about? If you don't specify it, it assume G0... I did think that the grob was already the first arg though in all of them. TW Although I work for HP, the views and opinions I post here are my own. |
09-30-2015, 07:37 AM
Why not to write ur own version which would call GETPIX_P -> Calculate Color -> PIXON_P ? Could be slow, but it is solution. I needed transparency, and it is supported, alpha blending really is not very useful.
09-30-2015, 06:06 PM
(09-30-2015 07:37 AM)xset Wrote: Why not to write ur own version which would call GETPIX_P -> Calculate Color -> PIXON_P ? Could be slow, but it is solution. I needed transparency, and it is supported, alpha blending really is not very useful. I created my own version using RECT_P and I did not have to do the calculation, because RECT_P supports alpha channel and I got BLIT_P with transparency. Code: BLIT_P_ALPHA(gd,x,y,a,gs) where: gd - destination GROB x,y - coordinates (destination) a - alpha channel (transparency from 0 to 255) gs - source GROB (GROB to draw with transparency) Of course we can check if version using method: GETPIX -> manual calculation -> PIXON maybe will be faster. I will check it later. -- Best regards, Piotr Kowalewski |
09-30-2015, 06:14 PM
RE: PIXON with alpha channel support | |||
