I rediscovered a comet using the HP Prime
09-28-2015, 02:43 PM
In order to investigate how practical it would be to process astronomical data on the HP Prime, I wrote a small prototype program to list the comets from a readable list obtained from the Minor Planets Centre.
Whilst checking this program, it became apparent that comet 138P was missing from the data. Here is the relevant fragment of the file downloaded last week. Code: Number Name Prov. Desig. Checking Wikipedia and other sources suggested this was 138P Shoemaker Levy. Comets can disappear but they would then normally be listed 138D, 138X etc., not just deleted. So I emailed the centre, and now the latest file is showing the comet - confirming that it is still a periodic comet. So as far as I am concerned, I rediscovered a missing comet using this little program on the HP Prime - and if the Prime were not such fun to use, that comet might still be missing. Code:
If you are still using the old data file, you will discover that this program interpolates the missing data for entry 138P. Though if you download the latest data you will see I have not been credited with the rediscovery :-( Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
10-15-2015, 05:31 PM
RE: I rediscovered a comet using the HP Prime
Just for the record, the data file with the missing comet was the one updated 2015 Sept 1.
