Is there a way to exit the Terminal display under program control?
01-21-2014, 06:20 AM
(This post was last modified: 01-21-2014 06:23 AM by veeblefester.)
Under program control, I need to exit the Terminal display after some PRINT lines.
Not PRINT(); but exit the display. Thanks in advance for any help. Happy coding and may you see ' i No errors in the program ' with every compilation. |
01-21-2014, 07:14 AM
RE: Is there a way to exit the Terminal display under program control?
Have you tried holding ON+T ?
My website: erwin.ried.cl |
01-21-2014, 07:27 AM
your question is not that easy to answer as long as you haven't defined to where you want to exit to. You may have a look at the STARTVIEW(n) command. N is an integer starting at 0. I've experimented with a short test program: EXPORT TermTst() BEGIN Print ("Test"); Getkey; Startview(0); END; and varied n from 0 to 9 ending up in different views like e.g. setup view, etc. but it seems it is depending from where you started. Starting from the Home View of the Function app resulted in setup or plot view but starting from the spreadsheet app e.g. only produced an orange exclmation mark instead of changing the view. Alas, the users manual seems to not say anything about this topic. Maybe Tim can sched some light so that experimenting is replaced by knowledge. Best regards Karl |
01-21-2014, 07:37 AM
RE: Is there a way to exit the Terminal display under program control? | |||
01-21-2014, 10:30 AM
Thanks for the feedback guys.
Unfortunately none of these offerings exits the Terminal display under program control. Need a line(s) that simply exits the Terminal display and displays whatever/wherever before the PRINT line(s). Happy coding and may you see ' i No errors in the program ' with every compilation. |
01-21-2014, 04:52 PM
(This post was last modified: 01-21-2014 04:53 PM by Tim Wessman.)
(01-21-2014 07:27 AM)Karl-Ludwig Butte Wrote: Alas, the users manual seems to not say anything about this topic. Maybe Tim can sched some light so that experimenting is replaced by knowledge. ?????? Page 482 or about there in the "STARTVIEW" command. Same will be found in the built in help on the calculator. As to why it doesn't go there... that means that view doesn't exist. Quote:Syntax: STARTVIEW(n [,draw?]) TW Although I work for HP, the views and opinions I post here are my own. |
01-22-2014, 08:04 AM
Hi Tim,
thanks for your advise. I noticed a difference in the pagecount: You wrote page 482 has the info in the users manual. I actually found it on page 546 in the July edition. Is there a newer version of the users manual? Alas, veeblefester is right: STARTVIEW() doesn't solve his problem. Is there any command which simply exits the terminal mode and displays whatever was on the screen before? I'm missing another function related to the PRINT command: One cannot specify the row and column where the expression should be printed. This would be an acceptable compromise for the also missing INFORM comand (see another post by me in this section of the forum). Best regards Karl |
01-22-2014, 03:53 PM
That was problably a much older one. I've got a few versions on the computer and I really should go through and delete all the old ones... :-|
