Proof of concept: how to profile poor performing programs
10-03-2015, 07:10 PM (This post was last modified: 10-03-2015 07:13 PM by eried.)
Hello, this is a little draft of a guide to analyze hp prime apps based on performance.
I am going to use an early version of the game Radioactive Wastes http://www.hpmuseum.org/forum/thread-4840.html by komame.
First my idea is to put the profiling information in the terminal (I noticed that the terminal is limited, so this will be a problem but it is OK as a general information about the method). I am going to use the comments:
[Image: 10.03.2015-15.54.png]
A simple regex should do the job. Now we run the modified app and copy the results to Excel or something similar:
[Image: 2015-10-03_1556.png]
The final column will just be the difference between events. Of course for a serious analysis is you need to define these in a much better way in your code, at the start of a function, or a loop you want to analyze.
Now I added a main category (I identified these after capturing some data) and then we use a pivot table/chart:
[Image: 2015-10-03_1600.png]
And finally we can see all the times each section took, averages, etc:
[Image: 10.03.2015-16.01.png]
Or more fancier ways to see the time impacts of the code segments:
[Image: 2015-10-03_1608.png]
[Image: 2015-10-03_1612.png]
(these last graphs are from Excel 2016)
My website: erwin.ried.cl
10-03-2015, 07:31 PM
RE: Proof of concept: how to profile poor performing programs
Amazing, I'm really impressed!
Piotr Kowalewski
User(s) browsing this thread:
