How the heck do I Iterate and Emulate?
10-04-2015, 07:18 AM (This post was last modified: 10-04-2015 07:42 AM by brickviking.)
I've got a HP-50G, but people have been humming about the Prime for a little while now. I installed the emulator, and I have upgraded to the 8151 version. I tried a really simple program in the HP emulator:
EXPORT ITTST()
LOCAL X;
PRINT("X is "+X);
ITERATE(X^2,X,2,3);
PRINT("X is now "+X);
All I get as output is "X is 0" (understandable) and "X is now 0" (which is not). Clearly I'm doing something completely wrong, as I typed the ITERATE example in from the manual, yet I'm not getting the same results as the manual. I also tried it in the Home screen, ITERATE worked fine there. So, where am I going wrong?
(Post 35)
Regards, BrickViking
HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a)
10-04-2015, 08:00 AM
RE: How the heck do I Iterate and Emulate?
ITERATE doesn't change the value of your local variable X.
You should do:
X:=ITERATE(X^2,X,2,3);
10-04-2015, 09:23 AM
(10-04-2015 08:00 AM)Didier Lachieze Wrote:  ITERATE doesn't change the value of your local variable X.
You should do:
Ahh, that would explain that. So it's a bit more like PASCAL than I previously thought. Thank you.
(Post 36)
