Comportement étrange
10-05-2015, 09:15 PM
(This post was last modified: 10-05-2015 09:16 PM by Tyann.)
Sur la calculatrice physique, entrez ce code:
Physics calculator, enter this code : Code:
il s'arrête, normal. Maintenant relancez le programme puis pointez avec vôtre doigt sur l'écran en différents endroits 3 fois minimum appuyez maintenant sur une touche, le programme ne s'arrête plus sauf avec la touche 'On'. Run this program and press any key he stops, normal . Now run the program again and then point with yours finger on the screen in different locations 3 times minimum Now press a key , the program will not stop except with the button 'On' .[/code] Sorry for my english |
10-06-2015, 09:16 PM
RE: Comportement étrange
I confirm this issue.
I think the problem is related to the command GETKEY that stop functioning properly when the screen is touched three times. Program stays in the loop until you press the ON key. Other keys just doesn't work. I checked also the version using REPEAT UNTIL loop (without WAIT) and this issue is also present. Code: EXPORT TEST() Piotr Kowalewski |
10-07-2015, 01:41 AM
I'll put it on the list...
Seems quite strange. TW Although I work for HP, the views and opinions I post here are my own. |
