Nice finding in a drawer
10-09-2015, 04:53 PM
(This post was last modified: 06-08-2022 07:54 AM by emece67.)
Today I have found this in a drawer at my work:
[img][/img] [img][/img] It is dated 1968. Not sure if it fits in the "HP handheld calculator" category :-) I'm not sure about its intended use. Apparently it can calculate the rise time measured by an scope as a function of the probe parameters, but the resistance range seems low (up to 10 kOhm) to me (perhaps that was the norm in 1968, but I cannot say). The back can compute the signal loss in the probe. |
10-09-2015, 11:12 PM
(This post was last modified: 10-09-2015 11:12 PM by cruff.)
RE: Nice finding in a drawer | |||
10-10-2015, 02:45 AM
(10-09-2015 11:12 PM)cruff Wrote:(10-09-2015 04:53 PM)emece67 Wrote: Today I have found this in a drawer at my work: They're working now, and the advantage of that "calculator" is, it doesn't require any batteries. All it requires is accuracy in setting. (Post 42) Regards, BrickViking HP-50g |Casio fx-9750G+ |Casio fx-9750GII (SH4a) |
10-10-2015, 04:48 AM
I get a message saying, "This Connection is Untrusted."
http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
10-10-2015, 09:41 AM
10-10-2015, 12:10 PM
Removed the s in https just now.
Don't you see the images "inline" in the post? I do not need to click anywhere to see them. |
10-10-2015, 01:00 PM
(This post was last modified: 10-10-2015 01:06 PM by Dave Frederickson.)
(10-09-2015 04:53 PM)emece67 Wrote: I'm not sure about its intended use. It appears to be a slide rule for determining the measurement error for oscilloscopes based on signal and probe characteristics. Find the manual for the 'scope pictured and maybe it'll have instructions. National Semiconductor once gave away similar slide rules for determining transmission line characteristics for PCB design, like trace impedance. I gave a set to a guy at work who collects slide rules and he hugged me! Dave Edit: Looks like TI has the calculator, now. http://www.ti.com/lit/an/snla035/snla035.pdf |
10-11-2015, 12:08 AM
Nice picture.
I assume we will have 3D printed reproductions available in a few days. 2speed HP41CX,int2XMEM+ZEN, HPIL+DEVEL, HPIL+X/IO, I/R, 82143, 82163, 82162 -25,35,45,55,65,67,70,80 |
11-05-2018, 02:29 PM
(10-11-2015 12:08 AM)TASP Wrote: I assume we will have 3D printed reproductions available in a few days.It took me a bit longer than that. And it's only 2D printed. And handles only the Pythagorean theorem. You can print pythagoras-slide-rule.pdf on thick paper and follow the build instructions of my presentation at the Allschwil Meeting 2018. Kind regards Thomas |
