Wallet
10-09-2015, 09:25 PM
Wallet
This is my first program. It's goal is to save personnal notes like passwords, ... This is the very first version, the encryption is done by XOR. I will add later a better algorithm, just the time to find it.
You can also import ASCII text from a PC. Open the Connectivity Kit and create a text file under the Wallet application. It is compatible with firmware 2015.6.17 (8151).
For downloading Wallet to the HP Prime, open the Connectivity Kit, unzip Wallet_1.0.zip and put the folder Wallet under the Application item.
More details are available in french at http://dudovc.free.fr/HPPrimeWallet.htm
.zip  Wallet_1.0.zip (Size: 4.94 KB / Downloads: 17)
Dimitri
