#Constant
10-10-2015, 09:24 AM
#Constant
Hi all,
Is it posible to define a constant in the HP Prime? like: Deg2Rad => pi/180 Cheers, Jan |
10-10-2015, 10:39 AM
RE: #Constant | |||
10-10-2015, 06:01 PM
RE: #Constant
(10-10-2015 10:39 AM)roadrunner Wrote: Do you mean something different than the Define function command (shift/Define)? Generally the "Define" is ok for calculations in HP Prime, but not for programming purposes. Equivalent of "const" like from other programming languages would be useful. Currently, it can be replaced by using variable, but the use of a "const" would definitely be faster and safer (to prevent overwriting of value). The use of variable requires reading its values everytime when it is used in program. In contrast, a constant is substituted at the stage of compilation and it is not needed to be reading during program execution. Piotr Kowalewski Radioactive Wastes - game for HP Prime |
10-12-2015, 06:53 AM
RE: #Constant
Nope, there is no such thing in PPL. Sorry. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
User(s) browsing this thread:
